caulking at baseboard heater
BobS | Posted in General Discussion on April 28, 2006 06:47am
Simple, maybe dumb, question here. I’ve got a gap at the end of my baseboard heater and the wall which I’d like to caulk for painting the room.
Do I need to use a firestop caulk or is regular acrylic latex + silicone acceptable? If the firestop, is it going to swell when the heats on enough that the paint will fail/look like crap?
Thanx
    IMERC | Apr 28, 2006 08:12am | #1
    use a polyurathane caulk..
    won't dry out like acrylic..
    WOW!!! What a Ride!
    1. BobS | Apr 28, 2006 04:36pm | #2
      Thanks, IMERC. I was hoping for something a little easier to work with but I'll take a look at the spec sheets.
        IMERC | Apr 28, 2006 04:53pm | #3
        folks use latex for that application all the time.. just seems to dry up and shrivel over time...
  2. DonCanDo | Apr 28, 2006 05:06pm | #4
    Unless the baseboard heater is already painted/caulked in place, I don't like to use caulk here.  For the very best paint job, I like to remove the cover pieces and usually the end cap needs to be removed first.  Caulking it to the wall would make it's removal difficult.
    Consider using a small piece of molding (maybe quarter round or cove) and lightly tacking it in place with a dab of glue.  Latex caulk would work, just don't use hot glue.
    -Don
    1. BobS | Apr 28, 2006 06:53pm | #5
      Hmm. I don't think I can take the cover off. Its rock lath walls and I think the heaters were put in after the sheetrock and then the brown coat of plaster and veneer coat went up. So the cover is recessed a bit into the wall. Thanks for the molding tip.I guess the main answer to my question is that I don't need firestop caulk.-bob
        IMERC | Apr 28, 2006 09:27pm | #6
        don't need it...Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming<!----><!----><!---->
Mortar for Old Masonry
