Caulking Butt Joints
joe68 | Posted in General Discussion on November 20, 2003 04:14am
When installing horizontal cedar siding should you caulk the butt joints?
Thanks!
  1. FastEddie1 | Nov 20, 2003 04:37am | #1
    Why would you have horizontal butt joints?  Seems like that's asking for trouble.
    Do it right, or do it twice.
  2. bigred | Nov 20, 2003 04:45am | #2
    If you are painting the siding, it can't hurt to caulk or prime the butt joints.  If you are in an area that receives lots of precipitation, a tar paper spline behind each butt joint is not a bad idea either.
  3. beasto | Nov 20, 2003 04:48am | #3
    I would suggest priming but let the structure breathe.
  4. xMikeSmith | Nov 20, 2003 05:03am | #4
    horizontal cedar siding ....is that the same as clapboards ?
    we always use a scarf joint with claps... and we prime both ends before we hang them... so, no caulk for us..
    with fibercement , we do a regular butt joint, with a n aluminum spline, and caulk
    Mike Smith   Rhode Island : Design / Build / Repair / Restore
  5. csnow | Nov 20, 2003 06:30pm | #5
    Another vote for scarf joints.  Allows expansion and contraction without a gap. A steep angle is better for more overlap (many tricks to accomplish), but 45 degrees is pretty good.  Felt piece to back it up is a good idea, though I just did a couple on a patch job with bits of adhesive membrane, and found this faster and easier (stays put).
    Suggest priming or otherwise sealing the raw ends.  Looking at any older building, you will see the joints fail first.
    You can caulk or even glue a scarf joint if you like.  Caulk in a butt joint would be unlikely to hold.
  6. MisterT | Nov 22, 2003 03:38am | #6
    The joint on my butt is vertical, and you keep your caulk away from it hear!!!
    Mr T
    Do not try this at home!
    1. FastEddie1 | Nov 22, 2003 06:48am | #7
      Ok, looks like my comment was way off base...ignorance I'm sure.  Can someone 'splain to me what a horizontal butt joint is...in this context?
      1. UncleDunc | Nov 22, 2003 07:12am | #8
        If you put up two pieces of horizontal siding end to end, because you don't have one piece that's long enough to fill the position, the joint where the two ends meet is vertical. He never said the joint was horizontal, just the siding.
        1. FastEddie1 | Nov 22, 2003 08:56am | #9
          Oops.  I was imagining something like horizontal board & batten...Do it right, or do it twice.
          1. UncleDunc | Nov 22, 2003 10:07am | #10
            I can see why that troubled your mind. It sounds like a really bad idea.
Grout-Free Shower Panels
  • A Postwar Comeback
