Caulking Exterior Windows
user-5449330 | Posted in General Discussion on August 12, 2021 12:42pm
Home owner here.
About 9 months ago, I had about 12 sets of window sashes replaced with new jambs(?) in our home.  The installer told me I still needed to caulk, but that I didn’t need to caulk the exterior of  the “jambs” (not sure about the terminology).
It seems to me the only thing left to caulk is where the window frame and exterior wall meet.  Am I missing something?  Any recommendations on which caulk to use?
    sawdust_steve | Aug 12, 2021 01:14pm | #1
    Why don't you attach a photo so we can see what you are talking about?
  2. Shep | Aug 12, 2021 07:11pm | #2
    My question is- why didn't the installer caulk the windows? IMO, its part of the job.
    1. user-5449330 | Aug 12, 2021 07:43pm | #3
      That's a good question. But I'm not sure what needs to be caulked. The installer stated that the area where the new jamb/channel meets the existing window frame did not need to be caulked. Is that true?
      1. Shep | Aug 13, 2021 02:25pm | #5
        What Calvin said. ANY gap will let water in. And that's something you definitely don't want. I don't know how your installer did it, but I run a bead of caulk against the old frame and push the replacement window into it, so there's no gaps. If I have to, I'll touch up the caulk the outside so that everything is well sealed.
        I also caulk the inside, so the HO doesn't have to do anything except replace the drapes. And actually, I usually do that, too.
  3. calvin | Aug 13, 2021 07:40am | #4
    It looks like you had replacement windows installed. The third pic shows where caulk is needed. The crack between the new jamb and old.
    The installer always finishes the job, except in your case.
    1. user-5449330 | Aug 16, 2021 09:53am | #8
      Thanks for the help......
    tfarwell | Aug 15, 2021 09:08pm | #6
    I'd caulk any gap in the assembly, except where the window slides (don't caulk it shut). I'd use a white polyurethane - not anything acrylic or silicone. If you have any larger gaps, put some backer rod in first. Use a good gun - I like red devil's one, should be $20 or less - its worth it.
      sawdust_steve | Aug 16, 2021 09:13am | #7
      Solid advice. Polyurethane is the boss. Stay away from sillycone!
      1. user-5449330 | Aug 16, 2021 09:54am | #10
        Thanks for taking the time to help me out.....
    2. user-5449330 | Aug 16, 2021 09:54am | #9
      Thanks, very helpful. Much appreciated.
  5. andy_engel | Aug 18, 2021 06:27am | #11
    Polyurethane (STPU) or polyether (STPE). Take your pick. Do not use silicone.
