Caulking molding
handygman | Posted in General Discussion on July 6, 2009 07:01am
I’ve been reading past posting about caulking molding. Is it general practice to caulk the edges of molding. Do you ask the client if they want caulk or not. Would this be an additional charge. What about molding that is stained, do you caulk it also.
thanks in advance
  1. KenHill3 | Jul 06, 2009 08:21am | #1
    I almost always caulk paint-grade moulding.
    Stain-grade, I usually do not caulk. The exception is when the moulding will not fasten tight to the wall- ie. the drywall and/or framing is wonky. If it is ME who has done the framing and drywall, then no caulk necessary, of course! :o)
    The Woodshed Tavern Backroom
    The Topics Too Hot For Taunton's Breaktime Forum Tavern
    1. handygman | Jul 06, 2009 02:28pm | #3
      Just to be clear, you said you usually don't caulk stain grade. Is that because it is stained, because I've painted stain grade molding. You also bring up a good point. Whose "job" is it to caulk, the painter or the carpenter, generally.
      thanks
      1. DonCanDo | Jul 06, 2009 03:28pm | #4
        I've painted stain grade too, but I assume he meant that he doesn't usually caulk stained molding.  Nor do I.
        It's the painter's job to caulk and fill nail holes.  I think that's as it should be since it's part of the finish.  Usually, I'm both the carpenter and the painter.  I have followed carpenters who have filled nail holes and even primed as part of their job.  Most of the time their work is fine, but I have seen them use the wrong materials (eg. silicone or latex caulk for nail holes) and that just makes my job as the painter that much harder.
  2. DonCanDo | Jul 06, 2009 01:27pm | #2
    Just like Kenhill3, I caulk those transitions and yes, I think it's general practice.  There's no "extra" charge for it.  It's part of a standard paint job.
    I do try and use as little as possible.  It's only there to hide any small gaps between the molding and wall.  If the gaps are too large for caulk (and they would have to be really big to not be able to caulk), I ask the customer if they want me to repair the molding.
  3. JMadson | Jul 06, 2009 03:34pm | #5
    I think another factor in caulking or not has to do with the color contrast between the molding and the wall.
    If you have white molding on a light painted wall, any gaps will be dark and very obvious. But if you have dark, stained molding, the gaps won't be as obvious and may not have to be filled.
    Personally, I like the look when painted molding is caulked all the way around. It just looks cleaner to me.
  4. Hudson Valley Carpenter | Jul 06, 2009 05:12pm | #6
    I use DAP painter's acrylic latex caulk for moldings.  As the name implies, it's perfect for paint grade trim, inside or outside.
    Very easy to work with, fills gaps up to 3/8". Water cleanup. 2 hour drying time before paint.  Available in a few colors too.  About $1.35/10oz tube at HD.
  5. handygman | Jul 07, 2009 06:12am | #7
    Well, thanks for the input. Looks like I'll be asking the client if they want the molding caulk, because I'm not use to caulking molding.
    Jeff_Clarke | Jul 08, 2009 02:01pm | #8
    Don't skimp on the quality of the sealant.   One of my pet peeves is that molding-to-sheetrock joints almost always open up after one heating season.   Usually the higher the quality of the sealant and wood the better - but not always.   I'm talking even backprimed (and in the case of crown, back-blocked) interior trim, which I am increasingly specifying to reduce shrinkage.
    Won't work for most people, but probably the best solution - unfortunately - is to allow things to sit for a season, then seal and paint the final coat.
    Worst issue for callbacks IMO.
