Caulking new tile installation
x_navyfc | Posted in Construction Techniques on September 4, 2020 07:26am
Quick question…
I’m grouting my shower this weekend. 3×6 subway tile on an acrylic base that was set in mortar. Hardibacker with liquid membrane.  Unsanded grout with a matching unsanded caulk.
I’ve learned that because of possible cracking, you want to caulk instead of grout at any change of plane.
Does it hurt to only fill those joints 1/2 way with grout to act as a caulking backer? Am I better off using backer rod or making multiple passes (after appropriate set up times)?
Do I caulk where the bottom tiles meet the shower pan, or leave open? I’ve heard some say to leave open for drainage. I don’t understand how any water behind the tile would be able to drain down to the bottom.
Thanks for your help, and have a great weekend!
  1. mgmahan | Sep 04, 2020 11:13am | #1
    "Does it hurt to only fill those joints 1/2 way with grout to act as a caulking backer? Am I better off using backer rod or making multiple passes (after appropriate set up times)?"
    If your joints are this big, then they're too big for unsanded grout.
    1. x_navyfc | Sep 04, 2020 11:19am | #2
      Thanks for the reply.
      I guess the multi-pass/backer rod question was more aimed at the tile/shower pan joint where it’s more deep than wide.
      Grout lines were made with 1/16” horseshoe shims.
      1. mgmahan | Sep 04, 2020 01:36pm | #3
        Either use backer or caulk. Don't use grout in this situation. Something I'm doing more and more now is masking before caulking.
        1. x_navyfc | Sep 04, 2020 02:14pm | #4
          Thank you
          1. calvin | Sep 05, 2020 07:51am | #5
            X,
            The main purpose for using backer rod is to limit the contact of the caulk to only two sides of a gap. Add a non moving contact point at the back and risk it separating what you wish to seal.
