caulking sawed concrete joints
BillWemyss | Posted in General Discussion on September 17, 2006 03:42am
I poured 30 yds of concrete for a turnaround and had my finisher come back the next day and cut lines in it.The mud wasn`t just rite or the blade on the saw wasn`t sharp whatever it has chipped and seperated at the joints.What is a commercial grade caulk I can fill these joints with?
  1. vintage1 | Sep 17, 2006 04:19pm | #1
    try Sonneborn SL-1.  It is a self leveling urethane, and according to their website, intended for your purpose.
    Matt | Sep 17, 2006 04:49pm | #2
    The concrete wasn't cured enough (obviously).   SL1 is the ticket.  You see it a commercial jobs (like shopping center flat work) all the time.
    A new concrete guy I'm getting ready to start with said he has a "green blade" that allows him to cut control joints in fresh concrete.  Anyone know anything about that?  Doesn't really make sense to me.  The problem is that the pieces of aggregate chip out.
    1. brownbagg | Sep 17, 2006 04:58pm | #3
      you really need to cut the joint has soon as you can walk on it. A slab can crack overnight.
      Edited 9/17/2006 9:59 am by brownbagg
        Matt | Sep 17, 2006 05:03pm | #4
        Know what a "green blade" is?  Maybe a diamond blade with none of the curf cuts in it?
        1. ponytl | Sep 17, 2006 05:08pm | #5
          might check the Norton site...   I don't know the difference in blades I have green, cured, asphalt blades ect... they all look about the same... green might be a finer grit...  but then i buy all my blades off ebay  .... where i think they call em whatever they think will sell
          p
            Matt | Sep 17, 2006 05:23pm | #6
            Thanks for the tip. Maybe it's the "
            High Speed Turbo - Contender
            Shown on this page: http://www.nortonclipper.com/Data/Element/Node/ProductLine/Product_line_edit.asp?ele_ch_id=L0000000000000002081
  3. gb93433 | Sep 17, 2006 08:20pm | #7
    There are saws designed to cut concrete without chipping. Recently one of the local concrete contractors bought a new saw to cut some concrete a few days after it was poured and it was without chips.
