Cedar Closet
tkiser | Posted in General Discussion on March 15, 2011 04:28am
We are building an addition the client wants to have cedar line the closets. My questions are the following:
1.  Should we install drywall and put the cedar over the drywall?
2.  Place tyvek over the studs than install the cedar directly over the studs?
I think we should install something over the walls to keep out the dust from the insulation.
Any comments greatly appreciated.
It is a ranch so ceiling will be to the outside
two colsets are exterior walls
  1. oldhand | Mar 15, 2011 06:13pm | #1
    depends....
    If your cedar is well milled, straight with t&g, ship lapped or splined edges you might put it right on the studs. Assuming also it is 1/2'' thick or better and not having too many loose knots.
    Lacking such integrity you might need to back the cedar up with d-wall or osb.
    I have installed it both ways, it just depends.
  2. DanH | Mar 15, 2011 08:23pm | #2
    Partly you need to consider the location.  If the closet is on the top floor you definitely need to rock the ceiling, for air-tightness, and should probably do the walls too.  And any other location where dust infiltration could be an issue you should rock the walls/ceiling.
    There is cheap/thin cedar closet lining that pretty much must be put over drywall or another solid surface.  (Note that if you use that and glue it up you should use a low-VOC glue, but one that's known to be compatible with cedar.)
  3. Piffin | Mar 15, 2011 09:52pm | #3
    1. yes to SR You need to consider fire spread.
    2. no to Tyvek. Tannins in cedar wil eat it right up
Mortar for Old Masonry
