Cedar shingle methods
AJinNZ | Posted in Construction Techniques on May 3, 2005 03:22am
I have a job to do building a pool house.
45 degree roof pitch. Can I ‘stick’ to the shingles well enough to get up and down and nail more on? OR, do I need some sorta scaffold type thingy?
If it seems like a dumb question its cos shingles are not at all common here. Corrugated iron is. I am used to that………
thanks
Everything, 100% of it, depends on how you look at it.
DW
  1. MikeSmith | May 03, 2005 04:28am | #1
    aj.... on that pitch  (12/12) you need roof jacks with planks on them... you nail them on ..
    the shingle you leave out where the jacks are, you slide under the jack, so it will be ther for later.. you work your way up the roof with probably 4' to 5' between  rows of staging planks....
    after you cap the ridge. you take your staging  planks down.. and you slide the shingle you stored into it's place... with the butt about 1/2" below it's final location.. you toe -nail it into place    with the  2 nails  angling up the roof ...
    then you tap the butt of the shingle into it's final place and the head of teh nails slides under the course above.. you work your way down and off the roof
      Sphere | May 03, 2005 04:57am | #4
      He'd need a lot more n that if they had OSHA there..
      Yur right on..but the Cougar paws boots are a blessing as well.
      as is a foam cushion, and a scabbard for the hatchett..( my 4 stitches attest)
      I am just getting the last 6 sq on of oak shakes on a 6/12..pics tomorrow.
      Why look here?
    2. AJinNZ | May 03, 2005 07:45am | #5
      Thanks for the info.
      Just one more thing. Brace yourself cos I'm not kidding.............
      Whatza roof jack??
      Never seen one. I have a picture in my head, but anyones guess if I got it right.
      No laffing though..........
      DW
        Sphere | May 03, 2005 07:57am | #6
        A metal bracket, that is either adjustable to pitch, or fixed at 45*....slotted holes , ya nailit in and can  remove by pushing ( or pounding) uphill to remove..
        They carry a plank, or toe board, to situatute ones self or stock
        We refer to them as brackets in different parts of the USA.
        about 10.00 or less..merican.
        SOP here, now that OSHA is gawking.
        These are the days of miracles and wonders, this is a long distance call...........
        Why look here?
  2. gordzco | May 03, 2005 04:47am | #2
    What Mike said.
    First cedar shingled roof I walked, was a repair on a Pioneer grain elevator.
    Had to climb down to repair on a rope thrown from the cuplola.
    Learned two things about cedar shingles that day, one I will never forget.
    Don't wear cowboy boots!
    1. Piffin | May 03, 2005 04:56am | #3
      LOL, no stirrups on them cedars!
Installing Prefinished Cabinet Molding
Use these assembly techniques when installing crown risers and molding to minimize visible gaps and nail holes.
