Cedar siding to plywood garage door
Lansdown | Posted in Construction Techniques on April 14, 2005 02:24am
Finally got my garage door installed. I am planning on glueing (PL) and nailing cedar siding to it. Since I have to glue it (plywood is 1/8″), I can’t apply a felt. The door came primed, should it be painted as well before the cedar goes on?
  1. csnow | Apr 14, 2005 03:04am | #1
    Sounds like a strange application of siding, but I would think you would want to backprime the siding prior to install.
    1. Lansdown | Apr 14, 2005 04:52am | #3
      I'll definately backprime (as I did to all the cedar on the house). Would you suggest a different method of applying the cedar.
  2. WayneL5 | Apr 14, 2005 04:16am | #2
    Don't forget to add the weight of your siding to the door weight and calculate the new spring size you need.  The easiest way is to weigh a few pieces on a bathroom scale and calculate it out.
    1. Lansdown | Apr 14, 2005 04:53am | #4
      The door installers will come back when the cedar is on and adjust the springs. They were sized according to the anticipated added weight.
  3. byrnesie | Apr 14, 2005 05:09am | #5
    Why don't you beef up the panel's sheathing with an added layer of 1/2" ply over the 1/8" or use maybe 3/4" ply strips PL adhered to the panels like vertical strapping to nail the siding to- the garage door guys are coming back to retension the springs anyway so you have that base covered already.
    1. Lansdown | Apr 14, 2005 05:17am | #6
      That's sounds like a good idea. Then I can add a layer of felt as well.
      1. byrnesie | Apr 14, 2005 06:27am | #7
        Probably would give the strapping a primer- the felt paper is meant to be a water jacket  (lets water wick out at the bottom), not your purpose with the overhead door, since you have a group of panels horizontally broken at each joint.
