Ceiling Finish
sasforge | Posted in Construction Techniques on August 18, 2024 11:24am
I’m using 1×6 T&G pine planks for the finished ceiling in a bedroom – should I place furring over the drywall to ensure a tight nailing??
  1. [email protected] | Aug 18, 2024 07:20pm | #1
    That seems unnecessary if you use the right nails. Personally I’d try to blind nail it with 2-1/2” 15 ga nails. I’d also recommended one coat of mud in the joints of the drywall so it’s a fire rated assembly.
  2. calvin | Aug 19, 2024 08:04am | #2
    If you are planning on a stain or paint finish, do at least a first coat before install. Movement of the wood will tell you why if you don’t.
