Ceiling Joists
Braydio68 | Posted in Construction Techniques on March 19, 2016 01:58am
WWe had our house built a year ago and just noticed the ceiling joists in the garage are a combination of 2×4 and 2x6s. The wood on the specs #2 dom hem fir. Is it acceptable to use two different sizes of lumber in a ceiling? The spacce is 19.5 X 20. Thanks
    Mike_Mahan | Mar 19, 2016 02:49pm | #1
    Truss
    That looks like the bottom chord of a truss to me.
  2. DanH | Mar 19, 2016 02:54pm | #2
    With a truss like that they can basically use whatever the engineer (which is in reality a computer program) says is OK.
    BossHog | Mar 19, 2016 09:12pm | #3
    Got some more pictures?  Maybe from further back?
    I have no idea what it is you're questioning.
  4. DanH | Mar 19, 2016 09:43pm | #4
    I note that, on the bottom chord that is in the foreground, the left side piece appears to have some "wane" on the top front edge.  (Ie, the edge of the board is missing, due to a bit of bark breaking off.)  This appears to be well within "spec", however.
    Overall, it would not be at all unusual for the the bottom chord ("joist") and the outermost diagonal rafter-like members to be, say, 2x6 while the diagonal braces in-between are 2x4.  And there could be many other combinations, depending on the particulars of the structure.
  5. mikedrums | Mar 24, 2016 01:20am | #5
    I agree with the others...
    Looks like a normal bottom, middle joint of a truss made with 2x4s.
    The gap you see on the bottom is simply a misalignment in the joint, which is all too common unfortunately.
    That particular truss connector plate is for 2x4 or 2x6 and will often be used at the joint of the web (or strut) diagonal members to the top or bottom chord by raising them up a little so they aren't connected to as much of the chords.
    The factories crank these things out in minutes and some of the guys in assembly aren't exactly detail oriented.  I've gotten trusses with trussplates only attached by two rows of teeth.  I've gotten them with chords that are split half way up their length.  Experienece will tell you to inspect them when they are delivered.  Have some nailing truss plates on hand and extra lumber to replace any defects.   That's just for anyone listening in.  :-)
    Anyway, those are perfectly "normal."  Don't try to load them down with a lot of storage on plywood.  They're probably not engineered for that.  You can do light stuff, boxes and Christmas orniments, etc.  But if you get too heavy, you could start to see nails popping and seems opening up in the garage ceiling.
