Ceiling not level enough for crown molding
royturning | Posted in General Discussion on November 2, 2012 09:31am
My 100 year-old house has a plaster on wood lath ceiling that slants up in one corner as it nears the stairwell. This hasn’t been a problem (not noticable) but now that I want to add crown molding it will be. It’s out as much as an inch over a six foot area.
My thought is to attach wire lath with plaster washers in the worst area and slather a 50-50 mix of Structo-Lite and Mason’s Mix (probably two coats), taper it off and finish coat it with drywall mud. I’ve had success with this method on walls but I’ve never had a ceiling this bad. Any advise on materials and/or process would be greatly appreciated.
I’d attach some photos but it didn’t work earlier.
  1. DanH | Nov 02, 2012 09:56pm | #1
    If the ceilings are high enough, don't attach the crown to the ceiling, but drop it down an inch or two.
      royturning | Nov 03, 2012 07:47pm | #3
      ceiling problem
      Thanks for the reply, unfortunatly the ceiling isn't high enough. I'm afraid the space showing between the top of the window trim, cap, and what will be the bottom of the crown isn't enough to fool the eye.
  2. calvin | Nov 02, 2012 10:27pm | #2
    Roy
    If you can, attach some "plaster grounds" to the perimeter and taper out to what's not bad.  This will guide you trowell or knife and give you a base to fill to.  Remove and fill in.
    Best of luck.
      royturning | Nov 03, 2012 08:02pm | #4
      ceiling problem
      Thanks, I'm thinking I should rent a rotary laser level and really see how far off everything is. I'm not sure if such a machine can cast a line at the very top, if so, it seems that I could screw on some plaster grounds that just kissed the laser line which would give me the perfect depth for the new plaster. Anyone out there that knows of a better way?
      1. DanH | Nov 03, 2012 09:37pm | #5
        Get the level and pencil mark a level line about 10" down.  Then measure up from there to find where everything is and what you want to adjust.
      2. calvin | Nov 04, 2012 06:46am | #6
        Roy
        Out of level is not always a bad thing.  Sure, if you plan on having cabinetry up there that will show the difference, then level is a good goal.
        Dips and waves are the killer.  Straighten as you can, carve out some small dips out of the molding so it sits higher.  90% of remodeling finish is fooling the eye.
        I have a line laser and like Dan mentions, use it for reference.  Set it up, walk around the room and measure down from the ceiling to the line and make note of the numbers (+ or -)  difference on a pc. of paper.  It's a quick way to see the variation and quickness of drop or rise.  No need to strike a line on a finished surface.  Heck, you don't even need to move furniture.
      royturning | Jul 02, 2013 09:45pm | #8
      Plaster materials follow-on question
      After seven months I'm finally getting back to this project. I'm wondering if my plan to use a 50/50 mix of Structo-Lite and mason's mix over wire lath (probably two coats) and then finish coat with drywall mudd is the right materials choice. I thank any of you that have experience in fixing plaster ceilings for sharing.
       Roy
      royturning | Jul 02, 2013 09:54pm | #9
       Roy
  3. oldhand | Nov 04, 2012 07:04pm | #7
    or...
    Maybe some small profile trim at the top joint?
    royturning | Jul 03, 2013 05:29pm | #10
    Now I get it
    I wasn't sure what "plaster grounds" were. I was thinking screws or small pieces of wood set at the level I wanted the final plaster to be. Now I'm thinking they will be long skinny strips, much like typical shims, only longer and as thick as the ceiling needs to be in the given area. I can cut them on my bandsaw.
    Thank you Finefinish, Calvin and the rest who responded. Now I have a plan that's doable.
       Roy
    1. DanH | Jul 03, 2013 08:52pm | #11
      Actually, they're the white gunk left in the pot after you brew the plaster.
        royturning | Jul 09, 2013 07:09pm | #15
        Plaster grounds
        DanH,
        You had me for a second - probably because I drink at least 12 cups of coffee a day.
  5. bm3301 | Jul 07, 2013 10:21pm | #12
    My suggestion would be to make either a block that has the distance down from the ceiling and out from the wall or a mock up an inside corner. Use this to then mark a line in the wall and ceiling in each corner outside corner. You may want to do the middle of each wall as well to see how bad it is. Snap a line connecting each corner. Set the crown to this line adjusting if it is really off the ceiling. To then fill to the ceiling install filler strips tapered as necessary. This can either be used to float the ceiling out or just painted with the crown
  6. 1110d | Jul 08, 2013 12:26pm | #13
    I seem to have a attratction to tough projects like yours'.  The question I have is if the dip or wave is in a corner, or the center of the wall?  The corners would make it really tough because the miters would be off.  If it's in the middle of the wall, it gets a bit easier.  With a colonial profile you can cope the top of the crown slightly to take some of a steep wave out.  After that, try twisting the crown so the bottom edge is straighter.  Do not try to make it perfect.  You'll be surprised with the two methods just how much of a defect you can absorb and still have the crown look good.
  7. IdahoDon | Jul 08, 2013 11:57pm | #14
    If I'm following a taper/plaster guy I'd yell at him to straighten that crap out before my crown goes up, but if it's all on me I'll normally screw down nailers to attach the crown to and scribe and grind a little wood off the low spots to minimize any gaps.  After it's all up it's much easier to see how far the patch material has to extend in order to not catch the eye. If it's in harsh light you might need to float it out a great deal, but if it's an area that's in the shadows you might get away with a lot.
