Ceiling problem
benko | Posted in General Discussion on December 18, 2008 06:38am
I have a octagon, cathedral ceiling that keeps cracking along the joints. I was wondering if anyone had a tip on a material or tecnique to conceal the joints. There is apparently alot of movement between the different sections of the octagon.
  1. ruffmike | Dec 18, 2008 08:10am | #1
    No-coat Ultraflex. We use the 325 usually. Great product.
    http://www.no-coat.com/NO-COAT/ARCHITECTS/Products/ULTRAFLEX/
    Use this on your inside angles. It won't crack unless you have a serious structural problem. I usually use hot mud to embed, but a good all purpose will do.
    Edit: if you have noticable movement, I would consider removing some drywall at the corners and tieing them together, probably with some type of Simpson conector. You are going to refinish anyway
                                Mike
        Small wheel turn by the fire and rod, big wheel turn by the grace of god.
    Edited 12/18/2008 12:21 am by ruffmike
    1. benko | Dec 19, 2008 12:13am | #4
      Thanks. I"ll look into that product. It looks like a good deal.
    CapnMac | Dec 18, 2008 08:30am | #2
    My first inclination would be to cut in an expansion joint along the bevels.  That would corral the movment of the differing planes.  I'd then fasten a trim piece, like a 1x4 or the like over the joint, fastening it to only the one side.  Then, and movement is what it is, and does not transfer over into broken joints or materiral cracks.
    Depending on the dimensions, I'd also be inclined to bit the bullet and receiling the space.  Now, that willl sound like a lot of work, and it is.
    However, it's even odds that the ceiling is fastened directly to the roof framing.  That situation has a number of compromises built in (NPI) at the best of times.  Roofs move in complicated ways.  Drywall moves in very few, and with very tiny tolerances (1/350).  Setting a separate ceiling structure under the roof allows for many things.  Proper insualtion for one; structure that does not move quite so much, either.
    But, those are my biases; others' differ.
  3. mike_maines | Dec 18, 2008 08:43pm | #3
    Ditto on the No-Coat.
