Ceiling suggestion for Home
AalinGaly | Posted in Construction Techniques on May 11, 2022 08:41am
Hi there,
We are planning to renovate our home. As our ceiling looks unattractive and old, we would like to upgrade our ceiling with decorative lights like shown in the image .
https://www.westernstatesmetalroofing.com/hubfs/images/blogs/metal-roofing-ceiling.jpg
When I spoke with my friends, they recommended me to use <a href=”https://tranquil.global/linear-ceiling-systems/”>metal baffle ceiling</a> or linear ceiling which is commonly known as false ceilings. Is there any other ceiling system I can opt to get a good lighting and rich look?
The ceiling height is 10feet, according to me, a false ceiling would not reduce the room’s height.
All your suggestions are welcomed.
    unclemike42 | May 12, 2022 08:21pm | #1
    What is above your 10 ft tall ceiling?
    and of course, any kind of ceiling you install under the current one will reduce the height of the room.
    Alternatives to metal include drywall, which can be installed on a system of metal or wood lath, shimmed to achieve a level, flat, surface.
    you can install any kind of lighting you like.
Old House Air-Sealing Basics
