Ceiling tile install per sq.ft. cost
EJCinc | Posted in Construction Techniques on March 3, 2005 12:13pm
Does anyone have a rough sq.ft. cost for installing suspended ceiling track and tile?
I’m figuring a rough estimate for a previous customer of ours who now wants us to do an office build out for him?  We’ve done some suspended ceiling before I just want to compare our numbers and see where we are at.
  1. BobKovacs | Mar 03, 2005 12:50am | #1
    Depends on a lot of things:
    - 2x2 or 2x4 grid?  More grid pieces and more tiles with the 2x2
    - 15/16" or 9/16" grid?  The 9/16 is more fussy
    - Flat lay-in tile, or tegular edge?  The tegular tiles are more work to cut and fit at edges/corners
    - How high is the structure you're hanging wires from?  How high is the ceiling itself?  Both will affect how fast you can go- I can set 8' grid and tiles from the ground if I have to (I'm 6'4), whereas 10' needs a Baker scaffold
    - Is the area wide open, or is it cut up into dozens of offices?
    See why a per SF price is so hard to give?  The big commercial ceiling guys I work with actually break jos down into different area types- big open spaces, cut up hallways, etc., and offices- and assign "levels of difficulty" and different prices to each.  Gotta look at all that stuff to get a good number and make money.
    Bob
  2. boulderbuilder | Mar 03, 2005 12:59am | #2
    $ 1.50/sq. ft standard installed USG
    $ 1.75/sq. ft nicer tile installed USG
    $ 4-5/sq.ft Hunter Douglas installed
    assuming typical everything (heights, obstructions, etc)
    jocobe | Mar 03, 2005 01:07am | #3
    I believe Jerrald Hayes formula of taking the materials and multiplying it by 2.5 or 3 usually works for me.
    ...I'm being funny =8-)
    jocobe
      JeffBuck | Mar 03, 2005 03:14am | #4
      and he does that math in his head ...
      guy won't even look at a calculator ...
      let alone a computer!
      Jeff  Buck Construction
         Artistry in Carpentry
              Pgh, PA
      1. mikerooney | Mar 03, 2005 03:54am | #5
        I use one of those machines that picks your lottery numbers.6 16 17 97 99
  4. EJCinc | Mar 03, 2005 08:14pm | #6
    Ok, according to Hawk our numbers are wihtin reason.  I just wanted to make sure I wasn't way out in left field.  I figured I would be way high if anything.
    I know nobody likes to give sq.ft. prices and I understand.  i was just in a hurry to double check myself and make myself feel better.
    It's actually about 1850 sq.ft.  One large "exercise room", a small hallway, and two small bathrooms.   Hanging off about 12' down to 9' height.  Flat lay in tiles.  Chicago grid.
Outdoor Lighting
