Celiling Fan Light
user-429284 | Posted in General Discussion on January 2, 2013 07:11am
Have a ceiling relatively new (6 mos. old) ceiling fan w/ OEM light kit. after leaving light on for 1 – 2 hours, 30 – 60 seconds after turning it off, it flashes like the old fashioned camera light bulbs. Just a single flash & that all. I am thinking there may be a capacitor in there? ideas?
Wink
  1. DanH | Jan 02, 2013 08:03pm | #1
    I would guess that this is a setup where the light and fan are controlled from a wall switch, but through a single pair of wires?  In that case the light switch is electronic.  And likely the lamp is fluorescent?  An electronic switch with fluorescent lamp is prone to this sort of thing.
    1. user-429284 | Jan 03, 2013 10:04pm | #2
      The switches are one double stack of single pole switches in a standard plastic box. one switch controls the light, other the fan. Ran #14 3+ wire. the white is common to both, red to light, black to fan.
      as I recall, the lights themselves are small pigtail florescents........what ever came w/ the kit.
      THANKS
      Wink
      1. DanH | Jan 03, 2013 10:11pm | #3
        In that case I'd guess that the flashing is occurring due to something going on in the CFL electronic ballast.  Probably, as you suggest, a capacitor discharging.
        I have seen fluorescents that "stutter" maybe 1-2 seconds after being turned off, but can't say that I've seen it tens of seconds later. Sounds like a poor ballast design.
