cement in pex tubing
thetigger | Posted in General Discussion on July 12, 2008 03:49am
3/4 PEX in foundation – subs poured sill and spilled some into one of the tubes which was not covered properly.
been there a while.
Can I get it out?
Tried electric snake end in electric drill.
i don’r think there is a lot, but thats a guess, of course.
can I use muratic acid? will it hurt the pex?
any other great ideas  ( outside of shooting the cement crew)
oh, help and bother!
Tigger
    IMERC | Jul 12, 2008 04:03am | #1
    straight vinegar...
    WOW!!! What a Ride!
  2. Billy | Jul 12, 2008 04:43am | #2
    What about applying some pressure to the other end of the tube and spitballing it out?
    Don't go over the rated pressure.
    Billy
      IMERC | Jul 12, 2008 04:57am | #4
      that's after the vinegar soak...
      1. Billy | Jul 12, 2008 05:09am | #6
        I thought that but didn't write it.  Thanks for spelling it out.
        Billy
    2. Piffin | Jul 12, 2008 04:30pm | #10
      and don't look down the end of the barrel to see if anything is moving
  3. Marson | Jul 12, 2008 04:48am | #3
    A couple of thoughts: You could try an experiment with muriatic acid. Scrap of PEX, glob of cement, etc. See what happens.
    Where is the glob? If it's above the slab, can you just lop it off and put a coupling on it?
      IMERC | Jul 12, 2008 04:58am | #5
      don't go with the muratic...
      1. Marson | Jul 12, 2008 06:01am | #7
        Care to elaborate? I'm just suggesting an experiment.
          IMERC | Jul 12, 2008 06:06am | #8
          vineagar does it cleaner and safer...
          1. thetigger | Jul 15, 2008 05:24am | #11
            update on plugged tube.  I have had vinegar sitting in it for a couple of days. It has made a bit of headway (some water seeps through from the other side when I put the hose in and use pressure) but it's not making alot of progress yet. If it's safe to use the muratic acid I'll give it a try if I don't see some real results by tomorrow morning.
            I appreciate all the help, guys.
            IMERC | Jul 15, 2008 05:34am | #12
            staright distilled white vinegar is still a better bet over muratic acid...
            IMERC | Jul 15, 2008 05:34am | #13
            you may have more in there than you realize....
          4. thetigger | Jul 20, 2008 05:48am | #14
            well - the saga has come to an end. We started getting some water through which inspired my help to drill with his fish wire even harder and we broke through the pex into the foundation somewhere. Oh well - we tried and I'll never know how much cement was in there so maybe there was no hope from the getgo.
            Anyway, I see a way I can run a new path from the HW heater over the top sill and back down behind the toilet to the shower which is only a few feet more and I don't think it will break any code rules. I 'll just have to find a way to hide it behind the toilet. Thanks to everybody who offered help here.
            Tigger
          Sphere | Jul 12, 2008 03:36pm | #9
          Muratic comes shipped in the same polyethlene, have at it.Spheramid Enterprises Architectural Woodworks
          You gonna play that thing?
          http://www.youtube.com/watch?v=32Ln-SpJsy0
