Cement pad
tinkv192 | Posted in Construction Techniques on November 9, 2016 06:56am
I poured a small cement pad for my deck step base. After doing so I had decided to widen the steps. The cement pad is 2′ x 5′ x 5″ deep. I need a foot more on both sides. Am I screwed or can I add on to the pad?
Dave
  1. DanH | Nov 09, 2016 07:43pm | #1
    You basically don't need the part in the middle, assuming that the stringers will rest on the extensions.  But it would probably be wise to insert some pins before pouring the new bits, to keep everything on the same level.
    Of course, you could just use concrete blocks.
Podcast Episode 691: Replacing Vinyl Siding, Sloping Concrete, and Flat vs. Pitched Roofs
Listeners write in about ground-source heat pumps and weatherstripping and ask questions about engineered siding, concrete that slopes the wrong way, and why houses have pitched roofs.
  • A Postwar Comeback
