Any suggestions?
In this FHB Podcast Segment, the team chats about the best way to build a paintable surface over an old wall.
Psychiatrist?
Cement siding over clapboard
Can you give me the name of yours.
The problem is that you either need a flat surface or you must lay the new planks exactly over the old ones. For plastic/aluminum siding they use the fanfold foam "insulation" to produce a flat surface, but that likely wouldn't work so well with fiber-cement. To lay new planks over the old they both must be about the same exposure and thickness (and generally FC is a bit on the thin side).
