Central Exhaust Ducting
Clewless1 | Posted in Energy, Heating & Insulation on June 18, 2008 07:40am
I’m installing a central exhaust system for a friend. Need a little tip to get me off center. Joining several baths to one fan using rigid ducts and ‘Y’. Trouble is, the Y’s that you buy seem like the air flow is against the grain of the seam. The upstream 2 legs should be straight ducts to put crimped ends into and have a crimped exit to put a straight duct into. I’m missing something simple (got CRS), here and forget even what I did two years ago … go figure. Thought I could buy the ‘reverse’ style Y, but apparently that is not the case.   … what am I forgetting/not understanding?
signed CRS
  1. rez | Jun 22, 2008 08:05pm | #1
    Greetings Clewless,
    This post, in response to your question, will bump the thread through the 'recent discussion' listing again which will increase it's viewing.
    Perhaps it will catch someone's attention that can help you with advice.
    Cheers
  2. Dave45 | Jun 22, 2008 08:11pm | #2
    You may have to go to a sheet metal shop, but I've seen Y's without any crimps.  If you can find them, you can buy a crimper for a few bucks and crimp whichever leg(s) you need to.
    1. Clewless1 | Jun 22, 2008 09:49pm | #3
      Right. I thought about that a little as an option. thanks much
Drafting the 2027 IRC
  • The New Old Colonial
