Ceramic tile floor stability
georgep | Posted in Construction Techniques on August 9, 2017 12:06pm
Hi,
I am going to be laying a ceramic tile floor In a 3 season porch.  The area is 13′ x 16′,  the subfloor is nailed and glued 3/4″ AdvanTech.  This is being done on Cape Cod so, because of the hurricane requirements the floor is very stable and solid.  Jumping up and done there is no bounce or vibration at all.  The tile will be a large tile, either 12″ or 14″ square or perhaps rectangular tiles.
I plan on putting down a layer of cement board before tiling.and then am considering using Ditra.  If I use the Ditra, do I need the cement board?
Because the room has large windows and will receive a lot of sun I am concerned about  expansion.  If I use the Ditra does that eliminate the need for expansion joints?
  1. Geoffrey | Sep 01, 2017 11:05pm | #1
    tile install
    George
    Skip the cement board in all cases.
    The important question is what's the construct of the floor? joist size and spacing?
    assuming 3/4" subfloor over 2x10 joist@16"O.C...........
    , install 1/2' or 5/8" plywood, A/C grade, glue and screw.  Install Ditra over that, then tile away
    Good Luck
    Geoff
  2. florida | Sep 04, 2017 12:52pm | #2
    Advantech is great stuff and will give you the base of a good floor. Since you're going to install cement board anyway I'd skip the Ditra. The cement board needs to be bonded to the Advantech with thinset and the Ditra needs to be bonded with thinset. No need for the second layer and you'd save a lot of money. I would not lay my tile on plywood especially on a porch.
  3. georgep | Sep 11, 2017 03:53pm | #3
    The joists are 2x12", 16" oc
    The joists are 2x12", 16" oc with a 14" double vlam as the midde suppoting beam.
  4. georgep | Sep 11, 2017 03:53pm | #4
FHB Podcast Segment: Roofing on Commercial vs. Residential Buildings
In certain scenarios, flat roofs make more sense than pitched roofs (and vice versa).
  • A Postwar Comeback
