Ceramic tile vs. concrete cracks
JLazaro317 | Posted in Construction Techniques on December 3, 2008 05:51am
Is there a crack isolation membrane that can be placed over a crack or joint in a concrete slabs to avoid the transferrance of the crack through the tile if/when movement occurs?
John
J.R. Lazaro Builders, Inc.
Indianapolis, In.
  1. jet | Dec 03, 2008 07:07am | #1
    Use Ditra
    http://www.schluter.com/6_1_ditra.aspx
    1. JLazaro317 | Dec 03, 2008 10:20pm | #4
      I was hoping to find an uncoupling membrane to use that could be used over the joints without doing the entire floor and also raise the height. I'm assuming this will add 1/4" or so.John
      Indianapolis, In.
      1. RobWes | Dec 04, 2008 01:05am | #5
        There is a membrane about .06 thick or so. I used it in my home. Forget the name. I still ended up with one crack about 3 feet of so out of a few hundred feet. I'm OK with it.
        1. JLazaro317 | Dec 04, 2008 01:52am | #6
          That is kind of what I was thinking. If you can remember the name, I would appreciate it so I can do some research. I hate doing a job more than once.John
          Indianapolis, In.
  2. MikeHennessy | Dec 03, 2008 04:32pm | #2
    Ditto Ditra.
    Mike Hennessy
    Pittsburgh, PA
    rjw | Dec 03, 2008 06:13pm | #3
    Schlutre-Ditra is probably your best bet. There are other products which do the same. Take a slow stroll down the tile aisle at your local big box.
    "Ask not what the world needs. Ask what makes you come alive... then go do it. Because what the world needs is people who have come alive."
    Howard Thurman
  4. STAINLESS | Dec 04, 2008 03:23am | #7
    Greets, JLazaro317.
    Many moons ago I used a product NOBLE SEAL, I believe it was called. It was a CPVC membrane, relatively thick, which was advertised to do what you are asking for. Can't really comment on the efficacy, however, as we sold the house 2 years after I put it down.
    Perhaps someone else will chime in with more current info. & a justified testimonial.
    PS: I'm not even sure if the company still exists!
    Sincerely,
     STAINLESS
    1. JLazaro317 | Dec 04, 2008 03:55am | #8
      NobleSeal¯ CIS
      Crack Isolation Sheet
      Protects thin-set tile from cracking by relieving the stress caused by horizontal movement in the substrate. Also, helps to preserve tile patterns by bridging control joints
      Still around......
      Thanks,John
      Indianapolis, In.
      1. RobWes | Dec 04, 2008 05:27am | #9
        What's the tile guru site? Johns Bridge or something like that. There's a ton of info there.
      2. STAINLESS | Dec 04, 2008 10:43pm | #10
        My pleasure.
        Sincerely,
        STAINLESS
  5. Scooter1 | Dec 05, 2008 01:41am | #11
    Yes.  Any good pvc or Ditra or some paint ons will prevent those cracks from migrating up.  If, however, they are still growing, this may be problematic.
    Regards, Scooter "I may be drunk, but you're crazy, and I'll be sober tomorrow." WC Fields, "Its a Gift" 1934
  6. Billy | Dec 05, 2008 07:09am | #12
    Ditra works well for that. If the crack has much vertical movement all bets are off. You can try Noble if you can't afford the extra height of the Ditra (but Ditra's not that much height).
    Ask more at http://www.johnbridge.com
    Billy
  7. andybuildz | Dec 07, 2008 03:07am | #13
    Ditra gets all thumbs up but if one wants you can try Redgard. http://www.custombuildingproducts.com/ProductCatalog/SurfacePrep/WaterproofingAntiFractureMembranes/RedGard.aspx
    I've had great results with this stuff for a number of different applications....but stilll...Ditra is at the top of the list. Even Home Depot carries it by me...as well as the Redgard
    edit: just happened to still have this on my mouse from another thread I added it to. This was the last place I used the Redgard....this past summer for a customer.
    http://picasaweb.google.com/andybuildz/BBQTILETOP#
    http://www.ramdass.org
    Edited 12/6/2008 7:10 pm ET by andybuildz
    1. JLazaro317 | Dec 07, 2008 03:19am | #14
      I'll check it out.
      Thanks,John
      Indianapolis, In.
Grout-Free Shower Panels
