I am ceramic tiling a bathroom floor and installing hardwood flooring in the ajoining room. Do I extend the tile or do I extend the hardwood in the threshold area in the door way between the two rooms? The door is a pocket door. Ed Ferrett
![](https://images.finehomebuilding.com/app/uploads/2024/04/29113159/BUILDING-SCIENCE-SYMPOSIUM-1-Large-thumb-16x9.jpeg)
Check out the lineup for the 2024 Building Science Symposium featuring experts like Steve Baczek, Dr. Joe Lstiburek, and more.
Ed
Split it right in the middle under the door. With the door shut, from bath-see tile, from adjoining room-see wood.
I agree with calvin...
I usually try to put my flooring transitions where the door will cover them when it is shut. I am assuming the heights of the two floors will be pretty close to the same. 3/4" hard wood vs backerboard, thinset and tile, you should end up within 1/8 of an inch... Just enough to leave 1/4" - 3/8" betwen the tile and hardwood ( just a little wider than a typical grout line) and make the transition with grout.
If you can't split it down the middle, get a stone or fake stone threshold to go between the two and have it "peek" out from under the door on the wood side. In fact, it's not a bad idea in any event, as it gives you a clean line to work the wood to.
