I need to re-glue a chair leg that has come out of its socket.
I tried using Gorilla Glue, but that lasted only about two months.
Is there a furniture glue designed specifically for such applications?
Any recommendations appreciated.
Learn the specific guidelines for location, spacing, and clearance for optimal safety.
Yeah, there's something called "Chair-Loc", but it works by swelling the wood. I don't know if it would work now that the wood is sealed by the Gorilla Glue.
You could shave the tenon down to the bare wood, clean the glue out of the mortise, and use veneer to fill the gap. If you do, use a real furniture glue, like Elmer's carpenter's wood glue or white glue.
View ImageThis stuff is from Lee Valley and it's particularly useful for when you've got one loose leg or rung and don't want to knock the whole chair apart to fix it.
It works on the swelling principle, too, so I don't know whether your Gorilla Glue treatment would put the kibosh on it.
If you do wind up taking apart the joint (or whole chair) to reglue it, use Lepage's yellow carpenters glue. Can't beat it; I don't use anything else for any kind of furniture or cabinet work.
Dinosaur
foolish men call Justice....
for regular wood glue to work well and have strength, the joint has to be tight.
If it's pretty loose, use some structural epoxy.
But DON'T use epoxy if its ANY kind of antique- the epoxy isn't reversable, and will lower the value of the piece.
Thanks for these suggestions - I agree.
I don't think the DAP Swell & Lock glue will be able to penetrate the wood because of the Gorilla Glue mishap. The joint is reasonably tight, but I'm doubtful regular wood glue will work for the same reason.
No - this is not an antique chair, so I think I will give epoxy a shot. Any particular type/brand to recommend?
