Chair Rail: Level or follow the flooor?
Nessmuk06268 | Posted in General Discussion on June 10, 2013 03:34am
We are installing chair rail in an older building now used for office space and meeting rooms.
1×4 with moulded top and bottom.
Floors are uneven. Varying 3/4″ or more. Level suspended ceilings.
Keep the chair rail level or follow the floor?
    MarkH | Jun 10, 2013 05:02pm | #1
    Level
  2. Pete | Jun 10, 2013 08:20pm | #2
    level
  3. DanH | Jun 14, 2013 09:49pm | #3
    Check other features such as window sills which may give visual cues as to the level of the chair rail.  Make sure that the rail will appear level relative to these cues (if present), even if that means making it unlevel.
    BossHog | Jun 16, 2013 07:20am | #4
    In an old building I could care less if something I'm putting in is level or not.  What's important is how it looks.
    My suggestion is to tack up a string line where the chair rail will go.  Eyeball that and see what you think.
  5. DanH | Jun 16, 2013 08:04am | #5
    Also, of course, if you will be installing wainscoting you need to make sure that where the floor is lowest (relative to the chair rail) the height between floor and rail doesn't exceed the height of your wainscoting pieces (after accounting for base and other trim).
