changing a paint finish – additives
MarkDMacLeod | Posted in General Discussion on September 12, 2009 04:25am
Hello – a simple and likely simpleminded question.
I have painted an entire room out with one colour – walls, doors, trim – everything. The trim and doors were nothing to look at and we wanted the room to have a simpler appearance anyways. It worked well and has given us the desired effect.
I have substantial paint (eggshell finish) left over. There are some surfaces that I would like to have a higher level of sheen – entry door to the room, bookcases. I feel pretty wasteful even buying a quart of a higher level of sheen paint in the same colour for such a small area to e painted.
Does anyone know of an additive that could be used with the eggshell paint to achieve a slightly higher level of sheen. I have heard of spar varnish being added to paint but have no experience and I don’t even know, but I suspect, that such a mix would work only with oil based paints.
Any suggestions or experience?
Mark
  1. RedfordHenry | Sep 12, 2009 04:33am | #1
    No experience.  Always nice to keep some of the original paint (in original condition) in case you ever need to do a touch up.  Rather than contaminate your extra paint with an additive (assuming one exists), maybe you can topcoat with glossy water based poly?  Just thinking out loud.
      Huck | Sep 12, 2009 07:33am | #2
      I did that over the latex on my office cabinets, to give them a tougher finish - worked greatView Image bakersfieldremodel.com
    BillHartmann | Sep 12, 2009 07:40am | #3
    Paint starts out glossy and flatten agents are added to give it lower glosses.
    I doubt that there is no practical way to remove those flatten agents.
    A glossy clear coat will increase the sheen. But it won't be quiet the same.
    But in a paint (vs a clear finish) it probably that much different from starting with the glossier finish.
  3. Piffin | Sep 12, 2009 02:01pm | #4
    you can add deglosser to flatten it but you can't add sheen.
    1. MarkDMacLeod | Sep 12, 2009 02:23pm | #5
      ok thanks everyone. It looks like I'm off to buy a quart of paint. Arrgh.The advice re using a poly finish was one I have used before. It worked well in that situation but I am hoping to avoid an additional application.Thanks again everyone for your advice
