Is there a recommended oil solvent that can be added to Skilsaw that can break up old, thick oil? I’m draining my two saws now, but I though it would be a good idea to get ALL of the bad oil out. On my Mag77 it’s pretty dark and comes out like molassas. My HD77 isn’t quite as bad, but still discolored and thick.
Also, can automotive gear oil (like hypoid 90) work here or do you HAVE to use the factory recommended oil. I’d buy the oil from a tool house, but they’re really out of the way and I have hypoid in the garage.
Thanks guys!
Malibu,
I've used Skil, automotive, and Slik50 90sae hypoid. They all worked for me, and I think the Slik50 is best, but that's just one mans opinion with to little of a data base to back him up.
To really clean them out you can use nonresidue brake cleaner. Don't plug 'em in while the BC is out and about.
SamT
Seems I read in the instructions for my Black&Decker to use kerosene to wash out old oil.
You get out of life what you put into it......minus taxes.
Marv
The full instructions are on skil's website in pdf. Run saw one minute, dump oil, fill with kerosene, run one minute, dump kerosene, refill with skil lubricant.
Thanks for reminding me it's way past time to do mine.
Smile. It could be worse. You could be me working for you.
Thanks for the replies- if I can't wait until Monday I'll use the hypoid 90 in the garage.
I'd be curious to know from some of you guys just how bad your oil is. Like I said, the oil in the Mag77 dripped out and looked just like molasses. Is that indicitive of somethin burning out? It seems to run fine, so I guess I'm OK.
Thanks everyone!
I don't have turpentine so I didn't change mine today but as I remember it is a thick oil like you describeSmile. It could be worse. You could be me working for you.
I changed mine out a while back, and it is reccommended in the manual to use kerosene. My old oil came out looking like Thanksgiving gravy...A weird milky brown, and a little chunky. Unfortunately, the only kerosene I could find was in the gallon size, so I now have enough to change the oil for the rest of my life.Young, poor, and eager to learn
First you gotta find a garage with a lift that will actually lift one of those suckers!
Make sure it is well supported before you get under it.
Actually I didnt realize they had room for oil inside, I thought they were filled with lead!!!
Mr T
Do not try this at home!
Just for you, Malibu, because I am a left coaster too. I have been a framing contractor for many years and in all those years neither I nor any of my boys have changed the oil in our Skilsaws. I have one that is going on 10 years with never a change. Some of the guys add oil if the saw leaks, but generally we just toss them out and buy a new one if we smoke the gears. It is a cruel life in framerland.
There's oil in my HD77?!
So where's the dipstick?
My boss says the dipstick is attached to the handle , haven't been able to find it yet tho.
