Cheap protection for SE cable
tab1 | Posted in General Discussion on September 20, 2007 04:13am
Maybe it was Sunday and all the stores were closed when he needed to hook this up?
I’ve also found 10/2 cable used for light switches.
Middle of a run K & T wiring splices that are just bare wire wrapped around a section of wire with a piece of insulation removed. Surely that wasn’t kosher, even for K & T?
New Romex from the box to the attic, where it’s wire nutted–no junction box, of course–to 5 feet of K & T?
I’m kind of afraid to keep looking. <g>
On the other hand, they DID take the time to label the cables in the attic with a Sharpie!
  1. England1 | Sep 20, 2007 05:30pm | #1
    Geez ... what a butcher. Keep looking and good luck!
    BillHartmann | Sep 20, 2007 05:58pm | #2
    Yes, he should have used conduit (gray) instead of PVC water pipe.
  3. edlee | Sep 21, 2007 03:08pm | #3
    Copper SE?  That's some pricy stuff, if that's what it is.
    Middle of a run K & T wiring splices that are just bare wire wrapped around a section of wire with a piece of insulation removed. Surely that wasn't kosher, even for K & T?
    That would have been acceptable if it were soldered then taped and the tap supported on each side with knobs.
    Ed
