check valve in place of air gap
Quickstep | Posted in General Discussion on March 25, 2005 11:41am
Even after searching the archives, I’m still trying to get my arms around the root purpose for the dishwasher air gap. I assume that it is to prevent the dishwasher from siphoning water from the trap back into the dishwasher after the pump stops. Or, I guess it  could be to prevent sewage from getting into the dishwasher if there was a backup.  Neither of these circumstances seems likely, but keeping sewage out of the dishwasher seems desirable. In any event, like many people, I dont want to occupy my only spare hole in the sink with an air gap. Can I accomplish the same thing with a check valve and a vented loop? The check valve would brevent a backup of sewage and the vented loop would prevent siphoning. Anybody think that will cover the same set of circumstances that the air gap would?
  1. glatt | Mar 26, 2005 12:07am | #1
    I've read that it's OK to just have a tall loop under the sink.  That's how our dishwasher was installed.  It seems to be working alright.
    from the Hometime site: "Loop the drain hose high up under the sink so if there's a clog in the sink drain, it won't immediately run down into the dishwasher. Some local codes may require additional measures to prevent this."
    1. DaveRicheson | Mar 26, 2005 12:59am | #2
      Check your local codes. A simple phone call to your heath dept. or plumbing inspector will get you the answer for your area.
      My caution on using a check valve would be to to use a backflow preventer instead. They are made for waste line and function like a check valve (same basic design, but uses a light weight rubber flapper instead of a metal one).
      Dave
      1. brownbagg | Mar 26, 2005 03:01am | #3
        only thing we have to do here is run the hose to the garabage disposel. no loop, no air gap
