I need to clean my chimney and need to find a custom sized brush for the flue. Inside measurement is 13″ x 17″. Any good sources you guys know of? I found one place that has custom ones but they are poly and say do not work on creosote.
Any ideas?
Edited 12/7/2009 10:03 pm ET by Oak River Mike
Yo! Look in the Web for chimney supply then look for a flat wire brush( HEAVY DUTY). the size is 13 X 18. You need heavy duty rods too, the ones you find in the hardware store are not stiff enough for that type of brush. When you sweep you need to put some muscle to move that brush. National Chimney Supply has warehouses in many parts of the states. Copperfield Chimney Supplies, also. Be safe upthere!
