Chimney Crown/Washcoat
Kungur | Posted in General Discussion on March 31, 2009 05:18am
I need to redo the top of my chimney as the mortar is cracked and has been causing a little bit of leakage. I have caulked the cracks but it is now time to bit the bullet and do a total redo.
What material is recommended? Just mortar? Mortar with and additive?
  1. Piffin | Mar 31, 2009 05:52pm | #1
    or a metal cap of copper or lead
  2. theslateman | Apr 01, 2009 01:47am | #2
    You could build it out with wood and pour a concrete cap like the one these guys just did.
    They're also stuccoing it to match the house.
  3. seeyou | Apr 01, 2009 12:27pm | #3
    Formed concrete is your best option. Mortar will crack again at some pint. Or as was mentioned, a metal cap keeps rain off of the top of the chimney as well as out of the flues and does double duty on varmints.
    http://www.grantlogancopper.com/shop?page=shop.browse&category_id=27
    http://www.quittintime.com/      View Image
    1. wane | Apr 01, 2009 03:08pm | #4
      I disagree, conc/mortar are maintenance pigs, get a metal pan made, caulk it, done ..
      1. seeyou | Apr 01, 2009 03:15pm | #5
        caulk it, done ..
        Yeah - that'll last a long time..........http://www.quittintime.com/      View Image
        1. Piffin | Apr 01, 2009 03:53pm | #6
          I wanna see the caulk to metal that will outlast crete
          1. seeyou | Apr 01, 2009 04:06pm | #7
            Me, three.http://www.quittintime.com/      View Image
          2. wane | Apr 01, 2009 07:00pm | #8
            concrete caps always crack, its a ()*&() lot easier to recaulk than smash off a conc cap and repour it .. metal pans are superior to concrete caps
          3. Henley | Apr 01, 2009 07:21pm | #9
            I guess your a Vinyl siding fan too.
          4. seeyou | Apr 01, 2009 07:39pm | #10
            It's a whole lot easier...........http://www.quittintime.com/      View Image
          5. Piffin | Apr 01, 2009 10:25pm | #11
            I can show you several concrete caps from five to fifty years old with no cracks.Methinks you see ones poured by guys who don't know how to mix a good drypack mud. That is just as bad as hacks who would just caulk a metal seam instead of soldering it in a situation like this.Point being, if you are doing a concrete cap, do it right. If you are doing a metal cap, do it right.
            because failing to make it right the first time means you get to do it again
          6. theslateman | Apr 01, 2009 10:33pm | #12
            Unless one subscribes to a tail light warranty !
