chimney for range hood duct?
collarandhames | Posted in General Discussion on October 12, 2009 05:33am
I’m in canada,, and it’s about to get cold.  Really cold.  I have my house all sealed up so tight that I have moisture issues,, and really need both a range hood and bath vent fan,, and/or an hrv.
I’m hoping to re-do my kitchen in the next couple of years,, but since I added a gas range, would really love to cobble together an exhaust hood for it.  There is a thimble in the kitchen not far from the range.
My concern is moisture/ decay of chimney.  Obviously this is a concern?  I believe there is tile liners,, or I could  easily drop a chimney liner down from the top.  Is there reason not to do this?  Like moisture dropping down and accumulating? It would be about a 14′ rise.
Thanks for posting your opinions.
dave
    AaronRosenthal | Oct 12, 2009 06:17am | #1
    Olympic Vancouver here.
    I have the same issue. My HVAC guy said even with the furnace and H2O tank (gas)on the chimney a liner would handle the range hood duct.
    Speak to a pro, tho.
    Quality repairs for your home.
    AaronR Construction
    Vancouver, Canada
    1. DanH | Oct 12, 2009 06:21am | #2
      That sounds suspicious to me.
      As I stood before the gates I realized that I never want to be as certain about anything as were the people who built this place. --Rabbi Sheila Peltz, on her visit to Auschwitz
        AaronRosenthal | Oct 12, 2009 06:31am | #3
        Why?Quality repairs for your home.
        AaronR ConstructionVancouver, Canada
        1. DanH | Oct 12, 2009 02:31pm | #5
          Having fan-forced air blowing into a flue sounds like a recipe for back drafting.
            AaronRosenthal | Oct 12, 2009 08:18pm | #6
            Correctomundo.
            Which is why when we spec'd mine, we involved a higher exit vent for the stove.Quality repairs for your home.
          2. collarandhames | Oct 12, 2009 10:55pm | #8
            Chimney is not hooked up to anything.
          3. DanH | Oct 13, 2009 01:21am | #9
            I was responding to this:"I have the same issue. My HVAC guy said even with the furnace and H2O tank (gas)on the chimney a liner would handle the range hood duct."
          4. collarandhames | Oct 13, 2009 02:59am | #10
            DanH,
            got it.  Thanks!
            IT would be a temp hook up to avoid knocking a hole threw the brick,, but I really should just pick a place for the stove long term and install  it normally.
            Thanks all for taking the time to post!
            dave
      2. collarandhames | Oct 12, 2009 06:32am | #4
        I can- and have punched holes threw for range hoods,, but it's a brick house, and , well,, I'd just have to patch it later- likely.
        I suppose the key would be to figure out the new lay-out first.  -out comes the graph paper!
  2. Scott | Oct 12, 2009 08:29pm | #7
    I've never heard of running a range hood vent up a chimney, but I suppose it could be done as long as it you are darn sure that it wouldn't have a negative effect on current and future use of the chimney.
    Is the range on an exterior wall? If so, have you considered punching a hole through the wall? The duct would be much shorter, which is always a good thing with range hoods.
    Scott.
