Choice of heater for hydronic baseboards.
Fiddler110 | Posted in Energy, Heating & Insulation on March 5, 2015 07:34am
I have a house in San Diego on which I added a new bathroom and extended 2 of the bedrooms. The original house is heated by a gas wall heater. The new bath and 2 bedrooms in the back have hydronic baseboard radiators. I have been heating them with a Takagi tankless that also supplies the heat for the hot water in the bathroom. It has been working10 years but with some problems. The shower gets a slug of cold water occasionally and the heaters take some tweaking to get started in the fall. I want to seperate the two systems and add a new heater. I could leave the Takagi for the baseboards and get a 30 gallon tank type for the shower and lav. Or the other way around. The baseboards are: one 6′, and two 4′ made with 1/2″ copper pipes with fins. I have a thermostat and a Taco recirculating pump. Since the two systems are combined, I have a mixing valve to add cold water to the domestic hot water and run the Takagi at 175 degrees. When I seperate them I could get rid of that.  Any ideas about which way to do it and what kind of heater (or boiler) to use?
  1. mark122 | Mar 06, 2015 09:20pm | #1
    am pretty green with the hydronics systems being used around here, but if you cant find a good hvac guy in your area to help you should check out john siegenthaler's book. very good, detailed and has tons of troubleshooting help.
  2. Fiddler110 | Mar 09, 2015 01:52am | #2
    New tact
    Okay. Now, I think I'll disconnect the Takagi from the shower and lav and just use it for the hydronic system. I will put in a new 30 gallon tank-type water heater for the shower and lav. If the Takagi still acts up, I will put in a second tank-type heater for the hydronic system. Question: how big a tank do I need for 3 baseboard heaters? One is 6' long and two are 4' long with 1/2" tubing.
    1. DanH | Mar 09, 2015 08:11am | #3
      The size of the tank is irrelevant for a baseboard system. It's the wattage of the heater that's important.  (And remember that, in double-element tanks, the design is usually such that only one element runs at a time.)
  3. frost | Mar 10, 2015 10:44am | #4
    Just had my Takagi die on me after 9 years.  When they go, they go quickly.  I put it in for radiant heat and domestic on the advice of a radiant co. in Vermont .  Poor choice as its extremely inefficient.  Is electricity so expensive in Ca as to rule it out for such a small amount of baseboard heat?  I'd think that the ease of installation and the cost savings over a water heater or boiler would make electric attractive, especially given your short heating season. FWIW, I had a new boiler and water tank installed and isolated radiant from domestic.  Painful, cost wise, but I'm so glad to be rid of the Takagi .
