What’s a good “rule of thumb” in choosing the proper size crown moulding for a room short of buying short lengths & holding them up?
When setting exterior doors over a foam-insulated foundation, add a lumber subsill that will fully support the door.
Brian:
If I read you correctly, you asking what width of crown you should use for a particular room/house? Interior trim molding needs to be in scale with other elements of the room, most notably, other trim and ceiling height.
How wide is the window/door/cased opening casings?
How wide is the base?
How high is the ceiling?
Here's a general idea of how we do it in the Southeast for low to mid priced houses:
8' ceiling height- 3 1/4" base
- 2 1/4" casing
- 2 5/8" or 3" chair rail (if any)
- 2 5/8 or 3 5/8" crown (if any)
9' ceiling height- 5" base
- 2 1/4" or 3 1/4" casing
- 4 1/4" chair rail (3" chair rail plus backer) (if any)
- (3 5/8 or 4 5/8" crown) and optional peices to build up the profile to ~ 6"
>9' ceiling height- 6+" base
- 3 1/4" casing
- 5 1/4" chair rail (3 1/2" chair rail plus backer)(if any)
- 4 5/8" crown built up to 6" inches or larger
There are no hard fast rules - the above are just some ideas.
Whats a good rule of thumb in choosing the proper size crown moulding for a room short of buying short lengths & holding them up?
