Cieling Radiant heat and crown moulding
mbdarch | Posted in Construction Techniques on May 21, 2002 07:31am
What is the proper way to install crown moulding when the ceiling has an electric radiant heat system that we do not want to nail into?  The contractor used construction adhesive at the ceiling connection, with mechanical fasteners (nails) at the wall intersection.
Being an architect, I am not allowed to tell him how to install it, but I am allowed to judge the final aesthetic results, and within 6 months, there are up to 5/8″ gaps at the cieling.
Any suggestions?
  1. villagehandyman | May 22, 2002 03:58am | #1
    the proper way to do crown if you cannot nail into the ceiling is to add in a corner block behind the mouldings nailing horizontal into the wall top plate no adhesive is necessary  just a clean fit . now if the ceiling is uneven you will see gaps if this is a paint grade situation just caulk but don't forget about the heat from the ceiling  sometimes a small gap or a shadow line is much less obvious than caulking I ran into similar problem in some house that had cement block walls  with wood framing and plastered ceilings the ceiling line would crack because of expansion  I covered the corner with crown and left the bottom edge floating. there were small gaps but it looked fine
    in trim and mouldings work 5/8 inch is not a gap. its falling off the wall.
                                        Bill
    Edited 5/21/2002 9:07:22 PM ET by village handyman
    Edited 5/21/2002 9:08:24 PM ET by village handyman
    Edited 5/21/2002 9:42:29 PM ET by village handyman
Choosing a Paintbrush
  • The New Old Colonial
