Cinder block cover up
zydecosarge | Posted in Construction Techniques on January 26, 2006 02:15am
I have a 1955 brick house built on cinder block.  Two to four feet is exposed, some of it is painted and some is not.  I would like to cover the cinderblock, which I think looks ugly.  Is there anything I can skim coat over it to give it a smooth finish.
    zak | Jan 26, 2006 02:49am | #1
    Stucco or mortar can be applied directly over concrete blocks, and it can be stained a bunch of different colors. Pressure wash beforehand.
    zak
    1. zydecosarge | Jan 26, 2006 04:35am | #4
      Zak,
      thank you, will mortar work over paint?
      zydecosarge
        zak | Jan 26, 2006 05:16am | #5
        No, the cinder blocks need to be able to suck up some of the water from the mortar/stucco to have the bond. I don't have any great new ideas for what you could do over a painted block wall.
        zak
  2. Brian | Jan 26, 2006 03:47am | #2
    zs - lowes has a product called block filler that claims to give a smooth coat over cinder block - it is a paint product, and pretty cheap. (but I've never used it)
    Treat every person you meet like you will know them the rest of your life - you just might!
    1. zydecosarge | Jan 26, 2006 04:34am | #3
      Thank you,
      I will check it out.
  3. WayneL5 | Jan 26, 2006 05:29am | #6
    To apply stucco over paint you'd sandblast the paint off.
    Block filler is another option.  It is a thickened paint that fills pores in the block so a continuous film of finish paint may be applied.  It doesn't hide the texture at all.
    Another possibility is to faux paint the block to look like stone.  Or apply 1/2" thick brick veneer.  Or apply siding down to within 12" of the ground.
    1. zydecosarge | Jan 26, 2006 05:32pm | #7
      Wayne and Zak;
      Thanks - I will try the filler first on some painted areas and then plan a strategy.
      zydeco sarge
    McDesign | Jan 26, 2006 07:36pm | #8
    Mechanically fasten / glue on 1/4" or 1/2" Hardibacker or Dura-rock ($9 for 3'x5'), and mesh tape and stucco that.  Cracks and the old surface won't telegraph through.
