Circuit/cabling for new wall ovens
bergsteiger1 | Posted in Energy, Heating & Insulation on November 7, 2009 08:01am
I am replacing a single wall oven with a double.  Current wire is 10/2 w/ground.  240v 20 amp breaker.
New 240v double oven says it draws 40amps.  Besides needing a new breaker, do I need to go to a larger wire?  Are 4 conductor wires & plug/recepatcles required now?  Total cable length is about 45′.
  1. JTC1 | Nov 07, 2009 08:33pm | #1
    >>>>  Besides needing a new breaker,<<
    40A, 2 pole
    >>> do I need to go to a larger wire?<<
    #8 awg minimum, can go larger if you like (#6).
    >>> Are 4 conductor wires & plug/recepatcles required now?<<
    Yes, in my locale.
    The pigtail cable to the plug needs to be #8 or larger also.
    Jim
    BillHartmann | Nov 07, 2009 08:47pm | #2
    "Are 4 conductor wires & plug/recepatcles required now? "
    The NEC says that 3 wire is fine for EXISTING installations and almost all appliances that I have seen have instructions for either installation.
    However, you have to run new cable so it has to meet the current rules which are 4 wires if your local has adopted the 96 NEC or later. But even if you are a location without codes the 4 wire is the better option.
    The NEC does not require a receptacle and plug. It can be hard wired, unless there is a local amendment that requires them.
    Not universal but most common is that free standing stove have plug and reptacle, but built in cook tops and ovens are hard wired using approprate splice to the appliance pig tail.
    1. bergsteiger1 | Nov 07, 2009 09:41pm | #3
      Thank you guys.  I'd better head on over to HD.
      1. edwardh1 | Nov 07, 2009 09:48pm | #4
        8 ga wire nuts I found at a hardware store- hard to work with
          BillHartmann | Nov 07, 2009 11:39pm | #5
          More commonly split bolts are used.And LOTS of insulation..
      2. JTC1 | Nov 08, 2009 12:22am | #6
        Ideal "big" blue wire nuts are listed for up to 2 - #6
        Work very well if you will leave some slack in the wire and follow their strip length recommendations.
        Available at HD, among others, here.
        Jim
        1. bergsteiger1 | Nov 08, 2009 12:43am | #7
          1. JTC1 | Nov 08, 2009 01:17am | #8
            Oops!
            Mis-quoted listed maximum capacity for Ideal wire nuts.......
            Ideal, "big" blue wire nuts are only listed for 1-#6 + 2-#8 max.
            Buchanan Cap, blue/gray, #73203, wire nuts are listed for 2-#6 max.
            Both specify a strip length of 3/4".
            Both are for copper conductors only.
            Used both in the past, both work as listed.
            Both are available at HD here.
            JimNever underestimate the value of a sharp pencil or good light.
          2. edwardh1 | Nov 08, 2009 05:25am | #9
            I had probs getting the wires to wrap on each other (twist)
          3. JTC1 | Nov 08, 2009 05:38am | #10
            That's what I figured.
            The extra long strip will help with that problem; or go longer still, then twist with linesman's pliers, trim and then twist on the nuts.
            Jim
            Edited 11/7/2009 9:40 pm ET by JTC1
            popawheelie | Nov 08, 2009 07:01pm | #12
            Extra long and then trim is a good suggestion.
            I use two pair of pliers. One to hold and one to twist. "There are three kinds of men: The one that learns by reading, the few who learn by observation and the rest of them have to pee on the electric fence for themselves."Will Rogers
          5. gfretwell | Nov 08, 2009 10:00am | #11
            They make some nice set screw, insulated splice blocks these days that are a lot cheaper than the Polaris. I think they were a few bucks each for 2 hole 14-4ga. They have a clear plastic cover and red plugs for the screw holes. I don't have the name but City Electric had them.
            That makes a very clean and secure splice.
