Circuit Trace
hrnichol | Posted in General Discussion on December 19, 2006 12:31pm
I have six walls in rooms where there are electrical circuits that haven’t been identified as to their path.
How do I trace their path without damaging the wall?  I have both ends, I just need to be able to trace the circuit within the wall.
Is there an istrument to do this?
Is there a particular technique with instruments like multi-meter?
Thank you
hrnichol
    skip555 | Dec 19, 2006 12:43am | #1
    greenlee wire finder locater
    http://www.greenlee.com/cat_docs/test.pdf
    page 32 in case the link doesnt take you there
    1. hrnichol | Dec 19, 2006 02:06am | #3
      Skip555 -- thank you very much.  I think that you have set me on the right path.
      hrnichol
  2. nikkiwood | Dec 19, 2006 02:02am | #2
    I'm curious about this myself.
    This might be a more workable link. Open this page, then click on "Tests and Measurements". This will allow you to go to the Page (32) Skip mentioned:
    http://www.greenlee.com/product/index.html
    IIRC, these devices are mucho bucks; why do you feel you need to trace the wire?
    "It is what we learn after we think we know it all, that counts."
    John Wooden 1910-
    1. hrnichol | Dec 19, 2006 02:16am | #4
      Good evening nikkiwood
      We are tracing three lights through six walls -- lights that did work but now do not.  The bulbs are good, there is current to the switches, but the lights are dead.
      To just open the wall to repair a break or replace a cable could be simple, if the routing is known.  Otherwise, it could be a very expensive project, these are finished walls.
      A stud finder was suggested, it is a great idea that did not work!
      The best tool for the job is often dear in price but cheaper than other solutions.
      hrnichol
      1. nikkiwood | Dec 19, 2006 02:34am | #5
        Is there a way you could rig to test the various wires with a plain continuity tester?Years ago, I remember making up a long range continuity test with a lantern battery, a 12v automotive bulb, and a long pice of bell wire. It worked very well, but I can't remember how I did it. Maybe somebody will come along here who knows about these things....********************************************************
        John Wooden 1910-
      skip555 | Dec 19, 2006 02:36am | #6
      thanks for fixing the link , I have problems sometimes with PDF linkstheir really not that expensive , $257.00 here https://www.tselectronic.com/greenlee_prog/508s.html?tse_Session=aec756165b78eda2fc936a2e6c583fb8theres a older one on ebay @ 9.99 WARNING (if you bid ) the old one on ebay cant be used on a energized circuit . Its like the one I used to have , works just fine as long as theres no power .http://cgi.ebay.com/PROGRESSIVE-ELECTRONICS-WIRE-FINDER-MODEL-508E-SYSTEM_W0QQitemZ300060821765QQihZ020QQcategoryZ26213QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
      Edited 12/18/2006 6:37 pm ET by skip555
    maddog3 | Dec 19, 2006 03:16am | #7
    ...." Is there a particular technique with instruments like multi-meter?..."
    if you have a multimeter try checking the wiring at the lights for voltage between the black and white wires at each fixture...
    I am thinking you have an open neutral , either in a switch box or a nearby recceptacle.
    .Wer ist jetzt der Idiot
    1. nikkiwood | Dec 19, 2006 03:36am | #8
      Can you tell me what "open neutral" means?********************************************************
      John Wooden 1910-
        maddog3 | Dec 19, 2006 03:54am | #10
        (A) an open neutral occurs when the "white " wire on receptacles and lighting fixtures becomes non-continuous or "open " which is either caused by a bad splice or an overload ....you will read 110v (nominal) to ground or the metal box, just not through a complete circuit. (B) an open neutral on a multi-wire circuit can wreak havoc in a very short time...as in seconds..... on equipment that is on or running.
        1. nikkiwood | Dec 19, 2006 03:58am | #11
          Thanks, that's about what I thought. But you made it very clear.********************************************************
          John Wooden 1910-
  4. McPlumb | Dec 19, 2006 03:40am | #9
    A multi meter and a good extention cord works for long distance continuity tester. Turn off power first its hard on meters.
