I’ve got a 3″ steel DWV line I need to fix. Got the bad pipe out but the Female threads are narfed up with rust and
Since you probably can't get hold of a tap that big, buy a 3" steel nipple and then file or grind two or three grooves that run perpendicular to the threads and use this as a chase to clean out the female threads. The depth of the grooves should be as deep as the root of the threads, or slightly deeper to create a recess to collect crud. Keep the edges of the grooves as square as you can to make them sharp.
Exactly, I have made taps from bolts like that many times, works really well for softer metals and hard woods.
This is my favorite idea so far. Believe me, if a fernco would half work it would be done already. Wire wheel brush will be the second option. Is there an option where I could skip the threads. Shave down a 3" pipe and stick it in there with some sort of sealent?
Heat the bejeezus outta it and thread in the PVC, it'll melt new threads. ( as a last resort)
thats exactly what you need to do.... put the PVC fitting in boling water... coat the screwed up steel in pipe dope to seal and for lube... with oven mits or a thick rag... grab the hot fitting and thread it on... it will go...
p
Once I get it threaded in there should I reach inside and smear some kind of hard drying plumbing stuff at the gap between the steel and PVC? Or maybe just smooth the pipe dope squeeze out around the inside, coating the left over steel threads?
i've never had a gap to deal with... so i never have
P
I would try a wire brush on a drill. That works well in situations like that. Some penetrating oil helps loosen the rust too.
cut the pipe, and use a no-hub coupling...faster cheeper easier
It looks like fengelman has the best idea, you wouldn't believe what a 3in. nipple would cost and a tap you would need a small loan, luck.
Getcha a needle file and chase out the bad threads.
Female threads? You're a better man than I Gunga Din.
Oh, that would suck.
You could probably rent tap that big, if you have a good tool rental in your area. Also, I like the suggestion of grinding perpendicular slots in a 3" nipple, but I would make then about every 1/4" or 1/2", or about 10 of them.
I'm not sure how well it would work, but you could try naval jelly and a wire brush. Any decent hardware store should carry it.
~ Ted W ~
Cheap Tools! - MyToolbox.net
Meet me at House & Builder!
