Cleaning flagstone
criddle | Posted in General Discussion on May 2, 2006 07:26am
I have a H.O. with a flagstone patio that has a gorgeous old oak at the outer edge.  When ever the patio was layed, it is obvious that it was never sealed(if that is possible).  There are black stains that I don’t know if it came from the oak or is some kind of mold/mildew problem.   The stains are not consistent in the various pieces as some are heavily stained and some are not that bad.  I’ve tried power washing that took some of the staining away, but not all.  I tried a test patch with bleach and nothing at all budged any more.  It only goes down a 1/16th (a piece of a layer flaked off and it was clean underneath) , so it isn’t coming from underneath.  So my questions are, what might it be, what could I use for cleaning and is there a sealer to prevent this from happening again?
  1. DK | May 02, 2006 08:53am | #1
    HD SELLS IN THERE PAINT DEPT. A CLEANER CALLED KRUD CUTTER AND IT WORKS WONDERS FOLLOW THE DIRECTIONS I USALLY JUST PUT THE STUFF IN A GARDEN TYPE SPRAYER DILLUTED / SPRAY ON LET IT SIT FOR A FEW MIN. / MAKE SURE YOU HAVE A GOOD HIGH PRESSUREPOWER WASHER LIKE 2000PSI AND THAT SHOULD DO THE TRICK
    GOOD LUCK DAN
