Cleaning Gaps in Decking
Strehrj | Posted in General Discussion on May 31, 2006 02:35am
I have a deck that is made from 5 ½ by 1 ½ Trex boards with typically 1/8 inch spacing between boards. The spacing between the boards varies and since I have a large amount of tree droppings falling on the deck the gaps between the boards gets jammed with the tree fallout. Cleaning out the gaps by using a pressure washer has not been too successful, and cleaning them by using a knife like tool is very labor intensive.
I would like to clean out the gaps and perhaps enlarge them to ¼ inch. I was considering using a circular saw with a blade that had a ¼” kerf (if that exists). Does anyone have any suggestions on how to clean and enlarge the gaps?
    JDMELLO | May 31, 2006 02:53am | #1
    I WOULD ENLARGE THE GAPS USING A ROUTER WITH A CARBIDE BIT.
    ONE QUARTER INCH MAY BE A BIT WIDE, YOU MAY PREFER 3/16".
    AFTER YOU ENLARGE THE GAPS YOU WILL BE ABLE TO RADIUS THE DECKING BOARD EDGES WITH A PILOTED ROUND OVER BIT.
    BE SURE TO USE HEARING AND EYE PROTECTION!
    GOOD LUCK.
    Edited 5/30/2006 7:55 pm ET by JDMELLO
    1. joewood | May 31, 2006 03:53am | #2
      This might help ..
      http://www.clearthedeck.com/product.htmlhttp://www.clearthedeck.com/images/Deckh2.jpg
