cleaning indoor basement concrete floor
buckteeth | Posted in General Discussion on August 29, 2010 01:40am
We have a 7 year old concrete basement floor that has stains from ‘wood stain’ and wall and ceiling paint.  Also, it was ‘sealed’ with some stuff that was pretty strong smelling a while after the floor cured.
We want to acid stain the floor. Is there a “proven” method to getting the wall paint off. I’m sure the Penofin won’t come up, but we want a brown acid stain anyhow and that’s what the siding was stained with. Hindsight is 20/20 – should have been more careful, but we thought (then) we’d cover the floor with something.
Thanks.
  1. DanH | Aug 29, 2010 03:49pm | #1
    Small amounts of wall paint can be scraped off, or, if stubborn, treated with "Oops!" or something similar (though using a remover will drive a bit of the stain deeper).  Large areas probably require a large-surface paint remover, if scraping doesn't work.
    (Though I suppose you could get a floor grinder and clean up a lot of the mess, though it would leave the ground areas looking different.)
    1. buckteeth | Aug 29, 2010 05:39pm | #2
      Thanks. Will give it a try. I considered a professional buffer or something.
A Practical Perfect Wall
  • The New Old Colonial
