clear silicone sealant alternative
ted | Posted in General Discussion on May 13, 2008 05:58am
Just finished putting up a stainless steel backsplash in my kitchen. Out of necessity I had to do it in sections. Without thinking about it prior to starting I now feel I should go ahead and seal the joints between the sections. But Based on my prior experience with silicone (peels at edges, discolors over time, can’t reseal over old silicone, etc.) I’d rather not use it. Any other alternatives I should consider? I’d like to use either clear or a metallic colored caulk.
    Luka | May 13, 2008 06:47am | #1
    Lexel.
    Politics: the blind insulting the blind.
    Click here for access to the Woodshed Tavern
  2. Piffin | May 13, 2008 02:24pm | #2
    GE makes various metalic silicones.
    But I would leave well enuf alone
  3. Danno | May 13, 2008 02:31pm | #3
    I second Luka's motion for Lexel. Good stuff.
  4. brownbagg | May 13, 2008 02:52pm | #4
    can you cut stainless steel back splash, like for electrical outlets
    1. Piffin | May 13, 2008 03:01pm | #5
      Yes. Drill holes at the four corners and use a jigsaw with metal blade.
      A grinder will overheat the metal and discolour it
      Ted W. | May 13, 2008 03:02pm | #6
      Yep.
      Beware that if you predrill "Don't center punch it first" as it will instantly harden that spot on the SS and you'll dull your drill bits. --------------------------------------------------------
      Cheap Tools at MyToolbox.netSee some of my work at AWorkOfWood.com
