Clearance between oven and cabinets?
jes | Posted in General Discussion on March 8, 2005 12:18pm
How much clearance is required between kitchen cabinet sides (3/4″ plywood) and a typical kitchen oven/stove?  I don’t have the manual for the oven, and i’m wondering how little space i can leave, as i’m trying to maximize the space in a small kitchen.
Jesse David
“Beware of the man who works hard to learn something, learns it, and finds himself no wiser than before,” Bokonon tells us. “He is full of murderous resentment of people who are ignorant without having come by their ignorance the hard way.”
    dryhter | Mar 08, 2005 01:14am | #1
    Usually 1/8 to1/4 in.
    DPR
  2. davidmeiland | Mar 08, 2005 03:54am | #2
    You can usually look up appliance info online, even for older models. If not, call the manufacturer. The clearance is usually minimal, but find out what the manufacturer specifies.
  3. spinnm | Mar 08, 2005 05:28am | #3
    Don't forget to factor in what type of countertop material and how you want those inside edges finished.  Sometimes that can make a difference.
    ShelleyinNM
  4. FastEddie1 | Mar 08, 2005 05:40am | #4
    Are you referring to the inside of a built-in oven cabinet?  Or the outside to a cooktop?  Inside a cabinet you basically need enough room to slide the oven in place.  Clearasnce to a cooktop needs a couple of inches.
Podcast Episode 691: Replacing Vinyl Siding, Sloping Concrete, and Flat vs. Pitched Roofs
Listeners write in about ground-source heat pumps and weatherstripping and ask questions about engineered siding, concrete that slopes the wrong way, and why houses have pitched roofs.
  • A Postwar Comeback
