This is how I do my closet systems. I would like critical feed back from anyone.
This compact detatched accessory dwelling has an efficient layout with a vaulted ceiling that enhances the sense of space.
Basically I like what I see T.C. As for critical feedback I can think of a few things.
But still I like what I see. Nice work. Keep posting.
ParadigmProjects.com | Paradigm-360.com | Mac4Construction.com
Very nice! The only thing I do differently is I don't use wide face frames on the vertical partitions, and I keep them up off the ground by about 6", for vacuuming purposes (I guess, not sure really, just like the look better...OK, and I don't use nice plywood like you do, I use particle board). - Huck
Looks good, really. It's more than what the "average" around here gets.
I'd second Jerrald on the metal poles. The seem more sturdy. I do prefer the K-V stuff we get here over the wood.
The painters that follow me would hunt me down and inject latex into my arteries if I fixed all my shelving before they arrived though. Or caulked or spackled before primer. If there's a way to save them grief (hey, try to mask that off sometime - it'll take you hours) do it. Unless they're just shooting wall paint on the shelves, in which case, inject them with 15 ga nails. I put it all together, fix the uprights and the cleats, and leave all the shelves loose until punch.
Last thing, I got this from Gary Katz's book - he cuts the bottoms back so there's only about 1 1/2" in contact with the floor. It looks good, it makes life easier on the carpet installer, and you don't really need a shelf at the floor to just put shoes on. Ever since I started doing things that way, nothing but happy campers.
Here is a closet I did last year. It shares some similarities with your work
I second the part about the pole. Here is mudroom we did, and in the photos you can see the kind of metal pole and fittings we use. It is not round in profile, but more of an upright oval with flatted sides.
I am a long ways from good supply sources, so I order them via the web from Hardware Hut. They are a great source of all kinds of hardware.
Thanks to everyone for the comments - lots of good points on ways to improve the next one - thanks
Looks good. I agree with the metal closet rods, I think they are sturdier, and hangers slide better on them.
One thing I noticed was the way you wrapped the baseboard onto the uprights. To me, baseboard should only be run on wall surfaces. I usually run uprights to the sub floor, then the flooring covers the cut edge.
I use white melamine shelving stock for the organizers, to save the painter some work. For shelf supports I rip 1x6 in thirds, 1x6 in half for the rod supports. The painter gives them a coat of flat white, and they blend right in with the melamine. Any cleating nailed to the wall gets painted the same as the wall color.
Edited 5/9/2005 8:01 pm ET by dustinf
Dear Tim, oops, Trim< A veryn nice job!! I think I might have tried to talk the client into a highr elevation on lower shelf. He, or she will collect more dust, because of it's lower proximity to floor. Also, I recently, Had to locate a systen close to a window. I to convince the client to use 45/ at the window, to bouncmore light. We never have all the info., at this end!! Good luck, and verynice job, Chuck Keller
Trim- I agree with everyone about the set up. Looks nice, but as a penalty for fixing the shelves, you should have to paint them - and use a different color on the walls. Along the lines of the steel pipe for clothes rods, I have tried emt, electrician's conduit, the larger ones. I had to fabricate brackets because the standard ones didn't fit, and I think I wound up with the old 1x4 with saw cuts, butthe tubing will hold up a tank and it's pretty easy to work. Good Luck.
Hammer,Believe it or not the painters tell me to install them and fasten them. They come behind and fill/calk then spray primer and paint. They then cut in the walls. I would not do it that way but these guys do a really good job so I do as they like.
That looks great !!!! No wire dipped in molten plastic.
