Cobble stone patio
| Posted in General Discussion on April 18, 2001 07:33am
I’m laying a cobble stone patio over the top of an existing concrete slab. I’m mortaring the stone down with a 3/8 gap in between the stones with the original intent of pouring grout to fill the gaps. Since I started the project I’ve heard that perhaps sweeping in dry grout and wetting it afterward is a good way to go. My question; Is this a good process to use outside and what to use for grout?? I’ve been told mortar is as good as anything, ideas?? suggestions ?? Thanks in advance.
  1. Ian.D.Gilham. | Apr 11, 2001 09:44pm | #1
    I would use a semi dry 3:1 mix of sand:cement (+ color if required), swept into the joints with a soft broom. Water afterwards with a fine rose watering can or similar. Sharp, or plasterers sand is best.
    1. Mike_Maines_ | Apr 14, 2001 02:08am | #2
      *I've done what you suggest on a fieldstone patio, the joints were bigger though. Held up for a couple of years before it started cracking. An easier method all around is stone dust, just sweep it in, no worries about mortar splashing out onto the stones. Compacts hard and plants don't like it much, at least no more than cracked mortar.Mike
      1. Rick_Morley | Apr 16, 2001 05:21am | #3
        *b from near wistahwayne, i agree with mike about the stone dust. if you live in a place that has a winter heaving and cracking could be a problem.
        1. Mongo_ | Apr 16, 2001 05:53am | #4
          *Rick..."Wistah" Ahh, yah...Warchestah?Grew up in Oakdale (West Boylston).
          1. Wayne_Meek | Apr 16, 2001 09:00pm | #5
            *Thanks for the help I'll let you know how it turns out.
          2. Ed_Hilton | Apr 16, 2001 10:13pm | #6
            *Mongo, not sure you're in the right part of the country. I spent 4 years in the Sturbridge area, and i would have expected to see "from neah wistah". Good eye, though - I didn't catch it until after your comment.
          3. Mongo_ | Apr 17, 2001 09:34am | #7
            *Ed, I'm down the road now, in CT. Oakdale (not on most maps) is just a few miles outside of wistah.A few nights ago on CNN they had a story about a city in central MA. The caption read "Warchester," they pronounced it the same.
          4. Rick_Morley | Apr 18, 2001 07:33pm | #8
            *b candy gram for mongohey i'm a little closer to leominstah than to wormtown.still cold in either place though
  2. Wayne_Meek | Apr 18, 2001 07:33pm | #9
    I'm laying a cobble stone patio over the top of an existing concrete slab. I'm mortaring the stone down with a 3/8 gap in between the stones with the original intent of pouring grout to fill the gaps. Since I started the project I've heard that perhaps sweeping in dry grout and wetting it afterward is a good way to go. My question; Is this a good process to use outside and what to use for grout?? I've been told mortar is as good as anything, ideas?? suggestions ?? Thanks in advance.
