Code way to install ceiling joists
Parforme | Posted in Construction Techniques on December 8, 2006 05:35am
Good day everyone
I am trying to find the right way to install ceiling joist in a garage being converted into an office. The top plate is at 8foot 9inch but I want the ceiling height to be 8 foot. What is the code way to install the ceiling joists?
Thanks for your sharing your knowledge.
  1. JoeArchitect | Dec 08, 2006 07:49pm | #1
    Did you consider hanging an Suspended Acoustical Tile ceiling system?
  2. Craigabooey | Dec 08, 2006 08:57pm | #2
    why do you want to lower the ceiling? A little more headroom in a garage is  always a good thing
    JDRHI | Dec 08, 2006 09:13pm | #3
    Whole lotta information missing for a complete answer.
    How big is the garage?( what is the ceiling span?)
    Will this ONLY be a ceiling? Or are you planned on using it for storage above?
    What are planning to store above?
    What will the finished ceiling material be?
    If its small enough...and its just a ceiling....a 2 x 6 ledger run along each of the long runs with 2 x 6 joists toenailed perpendicularly every 16" O/C. Maybe some joist hangers.
    Oh how they pound, raising the sound,
    o'er hill and dale, telling their tale,
    Gaily they ring while people sing
    songs of good cheer, Christmas is here....
    1. Parforme | Dec 08, 2006 10:10pm | #4
      Hi and thanks for the replies. The room is 11'6"wide x16' long and the ceiling will be 1/2" sheetrock.The ceiling span is 11'6"and the walls will be paneling thats the reason for only 8' walls. Right now its just the stud walls the garage is attached to the house. I wondered if you could just nail the 2x6 joists to the side of the 2x4 studs.
      1. TomW | Dec 08, 2006 10:39pm | #5
        Why not do a 16" soffit  around the room and keep the higher ceiling in the middle. The room will feel larger and you can still use the 8" paneling.
        1. Parforme | Dec 08, 2006 10:44pm | #6
          Great idea that would look great but I just want it simple and the least amount of time to complete.
          1. TomW | Dec 08, 2006 10:49pm | #7
            In that case raise the paneling up a bit and run a wider base at the bottom and some crown at the top to cover the gaps.
          2. Parforme | Dec 08, 2006 11:02pm | #8
            Sorry I didn't say that I am wanting to get by with the least amount of money spent This is a 55 year old home and I don't want to put much money in it for just an office.But I love your ideas.
          3. TomW | Dec 08, 2006 11:09pm | #9
            I guess I don't understand what the current ceiling is. The top plate is at 8'9", are there just roof rafters exposed currently? I was assuming that there were flat joists in place on the 8'9" top plate.
          4. Parforme | Dec 08, 2006 11:59pm | #10
            There are just roof rafters exposed currently and the cap plate for the exterior wall and the top plate for the interior house wall.
          5. Framer | Dec 09, 2006 12:44am | #11
            >> There are just roof rafters exposed currently and the cap plate for the exterior wall and the top plate for the interior house wall. <<Are there interior walls?Are there any collar ties nailed to the rafters?If there isn't, you will have to put them in.What size rafters do you have and what size ridge?Check your walls to see if they're straight and once they are, you can nail your 2x6's along side the studs right underneath the top plate. You will have to nail hurricane ties onto the rafters since the ceiling joists are not nailed into them. You have to see if this is code where you're from.They might want you to put a 2x6 band around the perimeter and hang the ceiling joists with joists hangers.Joe Carola
            Edited 12/8/2006 4:45 pm ET by Framer
          6. Parforme | Dec 09, 2006 01:26am | #12
            Hi, yes this is an old home I am just converting the garage to an office. It has a gable roof.
Deck Details for Durability
Freestanding with boxed stairs, this small deck is full of ideas for a long-lasting entry that will look great for years to come.
