Coextruded Cellular Core PVC?!
JohnT8 | Posted in General Discussion on April 19, 2007 08:23am
Went to Menards last night to pick up some 3″ PVC for a toilet drain (I’d like to use 4″, but the main line is 3″).
But anyway, I tell the guy what I was going to use it for and he gives me this Coextruded Cellular Core PVC.  What the heck is Coextruded Cellular Core PVC?!
I just wanted regular schedule 40 PVC.
“We ourselves feel that what we are doing is just a drop in the ocean. But the ocean would be less because of that missing drop.”
— Mother Teresa
    BillHartmann | Apr 19, 2007 09:23pm | #1
    It is a little ligther weight.
    Look at the end and you will see foam with a ridgid inside and outside surface.
    I *THINK* that I saw someplace that it's useage is limited to either only under ground not not for underground use.
    Glad that I could CLARIFIY that for you.
    1. JohnT8 | Apr 20, 2007 12:37am | #2
      Clear as mud.
      Why'd they have to go and mess with something I could understand?  Schedule 40, 3" PVC... I don't need CHOICES, just give me my dang 3" PVC!!
      "We ourselves feel that what we are doing is just a drop in the ocean. But the ocean would be less because of that missing drop."-- Mother Teresa
    2. JohnSprung | Apr 20, 2007 01:22am | #3
      Around here it's used underground for patio and landscaping drainage. Our kids' place has a run of it that goes about 80 ft. from the back patio to the street.  It's lightweight and cheap, white on the outside and black on the inside.  Lotsa fun snaking it out in the fall, too.   ;-)
      -- J.S.
    3. JohnT8 | Apr 20, 2007 07:24pm | #4
      Looks like the Coextruded Cellular Core PVC is the leading game in town for 3" PVC.  That is all the Lowes had.
  2. BillBrennen | Apr 20, 2007 07:27pm | #5
    ABS DWV piping (but not the fittings) has been sold with a cellular core for 10+ years. Looks like they found a way to do the same with PVC.
    Bill
    1. JohnT8 | Apr 20, 2007 07:35pm | #6
      So I shouldn't be worried that I'm installing some strange, experimental waste pipe that is going to crack open in 2 or 3 years?  Or one that won't hold its joints.
      1. BillBrennen | Apr 20, 2007 07:43pm | #7
        Go ahead and worry all you want. The coextruded PVC is less proven, so we do not really know yet how it will do. The old Sch 40 is well proven. Glad to be of service!Bill
        1. JohnT8 | Apr 24, 2007 07:14pm | #8
          It appears that the Coextruded Cellular Core has a different inside diameter than regular PVC, because that toilet flange sure didn't want to slide into it.
          "The lowest ebb is the turn of the tide."-- Henry Wadsworth Longfellow
    jonblakemore | Apr 24, 2007 08:37pm | #9
    John,
    The local term for that pipe you're talking about "foam core PVC". It does not have the crush resistance that regular PVC has. I have also been told that it makes more noise because it does not insulate as well and it will "crackle" more when expanding/contracting.
    It is lighter and less expensive, so that's why some like it.
    Jon Blakemore
