Coffer ceiling layout-need advice.
ubc | Posted in General Discussion on January 25, 2010 01:14am
I’m in need of some advice with respect to the layout for this ceiling. The ceiling height is 8′-6″. The floor joist run perpendicular to the fireplace. I’ll be using a hardwood maybe oak, cherry or walnut for the crown and ply veneer for beams and flat panels. What’s a good way to divide this up considering the longest length I can get in the ply is 8 or 10′ sheets?
  1. Dudley | Jan 25, 2010 02:10pm | #1
    see attached for ceiling pitures -- you could do something along these lines -- the long pieces are all one piece - nothing has been scabbed together
    File format
    1. Dudley | Jan 26, 2010 05:20pm | #3
      Here is another coffered ceiling that we saw on a site - it is not my work but would like to do something like this soon
  2. calvin | Jan 26, 2010 10:22am | #2
    I can't help you with
    I can't help you with figuring your layout but will give you a link to a job I did that had similar parameters with material size. I used 4x8 beadbd panels in a more square room than you have shown. The bead repeats added to the complications in sizing the panels.
    I plotted it out to scale on paper and ran the couple ideas by the homowner. They picked what I ended up doing. I was able to plot it out on the floor and transfer the layout up to the ceiling using both line and dot lasers. The wacky-ness of the room made this even more fun.
    Best of luck
    Here's a link to a thread on the space.
    http://www.quittintime.com/ubbthreads/showflat.php/Cat/0/Number/10953/an/0/page/0#Post10953
  3. linuxguymd | Jan 30, 2010 09:33pm | #4
    I just finished a coffered ceiling in a room of the same size. The first part of my design was about how many coffers and how they lined-up with features in the room such as your fireplace. I used sketchup to compare how a 3x3 grid looked vs 4x4 or 3x4. To my eye, more coffers had a "heavier" look.
    You may have seen coffered ceiling articles on this site which describe types of joints at the coffer intersections (butt, diamond, etc) There is also a good article (free!) by Gary Katz on jlconline.com . I used 3/4" finger joint so that all joints could be joined using glue and dominos.
