Cold fireplace.
crofts | Posted in Energy, Heating & Insulation on February 12, 2008 07:03am
I live in southern Canada and am having trouble with cold coming in around the fireplace.  I have a metal fireplace which uses outside air for combustion and it works very efficiently when lit.  The problem is that there is no insulation between the wooden chimney chase and the metal of the firebox  so it becomes very cold when there is no fire.  Also drafts come in between the firebox and the brick surround in the house.  I need some ideas about how to seal the small gap between the metal and the brick, and how to insulate the chimney chase without creating a fire hazard.
Thanks for the input.
  1. rez | Feb 16, 2008 07:35pm | #1
    Greetings crofts,
    As a first time poster Welcome to Breaktime.
    This post, in response to your question, will bump the thread through the 'recent discussion' listing again which will increase it's viewing.
    Perhaps it will catch someone's attention that can help you with advice.
    Cheers
    Peach full,
    easy feelin'.
  2. danski0224 | Feb 16, 2008 07:40pm | #2
    The only way to insulate your chase is to use the material of your choice in the wall cavities, then cover the interior with at least one layer of 5/8" type X drywall with all seams taped. Difficult to do once the house is done.
    The fireplace to brick gap can be sealed with silicone caulking.
How Trump's “Big Beautiful Bill” Will Affect the Inflation Reduction Act
The Big Beautiful Bill could do away with much of the Inflation Reduction Act, including the 25C, 25D and 45L tax credits.
